Sep 01, 2013, 08:33 PM
shockflyer12345's Avatar
The AXIOM, my newest design!
Hi everyone,
I would like to present my latest design, the Axiom. The Axiom was designed with a goal in mind: to create an aircraft that is capable of both slow pattern flight, while also being able to perform crazy aerobatic maneuvers like an aeromusical model.
The Axiom is a large model, with almost 253.5 square inches of wing area, and almost 260 square inches of fuselage area.
Specs
WS: 35.25" (89.54 cm)
Length: 36.7" (93.22 cm)
AUW: 5.7oz (161.5g)
Wing area:253.5"^2
Fuselage area:261"^2
Wing Loading: 3.23 oz/ft^2
Despite the model having almost 690 square inches of foam used, the bare gediplac parts weigh a mere 38 grams thanks to milling! Nearly 6.6g was eliminated by milling (this was with a conservative amount of milling too)
Electronics used
Motor: Hack A10-9L
Esc: Turnigy Plush 6A
Servos: HS65MG (Ailerons), Dymond 47 (Strength version, elevator/rudder)
Rx: Lemon Rx 6 Channel
Battery: Turnight Nano-Tech 2cell 300MAH 35-70C
Thank you guys for looking. Feel free to contact me by PM if you have any questions!
-Shock
Axiom v3 info!
Hi guys,
I just wanted to talk a little about the Axiom V3, and give some specs.
Specs:
AUW: 5.0-6.0 oz
Wing area: 261"^2
Fuselage area: 254"^2
Recommended equipment:
Motor: Hack A10-9L or Axi 2203/RACE
Esc: Turnigy Plush 6A (Esc of your choice, should weigh under 8 grams)
Servos: HS65MG (Ailerons), Dymond 47(Strength version)/Futaba s3114
Battery: 300-360mah 2/3cell, should weigh under 20g
The main changes made from V2 to V3 were: increased wing area, modified milling template to maximize weight loss, increased control surface areas.
Plans are now for sale!!
It is $10 for a set of plans. This includes cutting templates, milling templates, and hardware templates.
Please understand that this will help me develop future versions of the Axiom line. I currently have an F3P in the works! Stay tuned!
Please check out my website for more information! http://NG-Design.webs.com
Sep 03, 2013, 07:32 PM
Video!
I now have some video of the model. Enjoy! (Forgive my crappy piloting skills )
Axiom V2 (1 min 51 sec)
Shock
Sep 30, 2013, 12:27 AM
vtol fan
nadine's Avatar
Originally Posted by shockflyer12345
Hi everyone,
Specs
AUW: 5.7oz (161.5g)
Wing area:253.5"^2
Electronics used
Motor: Hack A10-9L
This is Version 2 of my Axiom model. I currently have a V3 in the works.
*** I am currently looking for TWO MORE beta testers for the AXIOM V3 MODEL! PM me or email me at [email protected]
****This is for plans, not a kit!
IF there is enough interest in my model I will consider realeasing my AXIOM V3 plans
-Shock
Plans,it will be wonderfull...
Cheers
Sep 30, 2013, 09:20 AM
ME at Cal Poly
Free's Avatar
Here is mine before I milled it.
Free
Oct 14, 2013, 01:04 PM
God is Good
TMAC4123's Avatar
WHY A 65MG?????? I use those on my 48" extra
Oct 14, 2013, 02:14 PM
The ailerons are huge ! The HS65MG is great for this for two reasons: 1) It is fast, 2) It has high torque, and I dont have to worry about stripped gears. Since this model is only running one aileron servo it needs to be good. Sure, a smaller, lighter servo could be used, but it will limit the models performance, and it won't be able to fly like it is intended to.
Oct 21, 2013, 05:02 PM
ME at Cal Poly
Free's Avatar
Here mine Axiom V3, finished and AWESOME!
I have flown 3 batteries though it, and love it! I will post more pics and a video soon.(and do a build thread)
Enjoy! Thank you Shockflyer12345!! Great plane!
Free
Oct 21, 2013, 05:29 PM
Off playing tug
ChrisBowker's Avatar
I'm also a big fan of the hs-65 as an aileron servo on my foamies.
Chris
Oct 21, 2013, 05:59 PM
ME at Cal Poly
Free's Avatar
I am using 2 S3114s, they give me great roll response!
Free
Nov 29, 2013, 04:22 PM
ME at Cal Poly
Free's Avatar
See my new build thread in the Indoor Pattern/F3P section.
Free
Dec 01, 2013, 06:58 PM
hi there
i would love to build from a set of plans for V3! please?
Dec 01, 2013, 07:03 PM
ME at Cal Poly
Free's Avatar
I can't provide you with plans, but if you can get them, the plane is a blast!! You won't be disappointed! If you can, be sure to mill it. If not, no big deal.
Good luck!
Free
Dec 01, 2013, 07:06 PM
ME at Cal Poly
Free's Avatar
By milling, I got my foam parts to a mere 31 grams!!
Have fun!
Free
Dec 10, 2013, 11:32 AM
hi there,
i would love to start building and i havent been able to get v3 plans... how different is v2? do you know what changed?
