Aug 30, 2013, 11:48 PM
Hi guys i got a silly question when to use 3s battery and when to use 4s and up with
Hi guys i got a silly question when to use 3s battery and when to use 4s and up with your multicopter ????
Aug 31, 2013, 12:00 AM
You don't typically swap between them, as you would needs different props at the very least when you did.
Typically you want your quad to hover at about 50% throttle. If you do that with 4S then hovering at 3S will be up about 65-70% probably unless you put on larger props.
4S batteries are heavier, but give more power, so on smaller craft 3S is usually used, on larger craft, or if you want to lift payload then you'd run 4S or more
Aug 31, 2013, 01:31 AM
thanks one more question got a naza lite installed in gaui 500 which has 960kv guai motor and i used 3s5000 mah it only give me 5 min of flying total weight is 1kg-1.5 include the battery it has 10x4.7 battery what i am doing wrong here ???
Aug 31, 2013, 02:02 AM
Have you calibrated the Naza's voltage alarm? They are usually a long way out, or _very_ conservative.
The general rule with a LiPo is you only want to drain 80%. I'm betting you're only draining about 20-30%. You can tell this by seeing how much your charger puts back in. Likely way way less than the 80% value of 4000mah
Aug 31, 2013, 12:01 PM
regarding the calibration I connected to the software and went to battery voltage and clicked on the calibration if some thing else I might missing regarding that plz let me know thanks
Aug 31, 2013, 03:01 PM
I've never had a Naza, but my understanding is you need to read the battery voltage with a multimeter and then input that number into the Naza software with the same battery connected. From there you can also lower the low voltage warning value until your charger is continually putting about 80% of the battery capacity back in
Discussion Hi Kv with 5s-6s or hi Kv with 3s-4s? zaguruinzasky Power Systems 5 Aug 07, 2013 02:16 AM
Discussion Battery question 3s vs 4s Agalloch Multirotor Drone Power Systems 14 Jun 17, 2013 11:42 AM
Discussion Silly question - what type of pen do you use? Makdaddy Foamies (Scratchbuilt) 7 Jun 07, 2013 10:10 AM
Discussion Lipo Rx Batteries - silly question? MCarlton Radios 3 May 27, 2013 08:16 AM
Discussion 2 Straight up questions - What charger do you use and how do you store your batteries Excogitate Batteries and Chargers 4 Mar 25, 2013 12:24 PM
