Slow Stick from Hobbyking? - Page 5 - RC Groups
Jul 19, 2014, 11:09 AM
If doing aerobatics, pls note that there is a slot in the middle, underside of the wing where I glued a carbon fibre piece, I think it was 3x3mm square. This fill up the slot in the the wooden piece also - without the CF piece you will almsot certainly fold the wing in the air.
Jul 19, 2014, 11:11 AM
Originally Posted by SilbernerSurfer
How can i get the motor mount off from the HK Slow Stick?
It is glued with CA and a hell to get off, I tried but almost destroyed the 10x10mm square CF tube. Buy a new CF square instead which is 800mm long so you dont need to use the white plastic connector.
Jul 19, 2014, 12:14 PM
I dont like crashes!
I have thought about buying a new CF tube. But i have to remove all the white plastic mounts for the wings and servos. They also are glued on with CA.
I am bathing the Motor mount in Acetone since yesterday, but the motor mount doesnt move any mm.
Lets see what it makes in some days. :-)
Jul 19, 2014, 01:53 PM
SUCCESS!!!!!
After a bath in acetone for about 6 hours the motor mount was easy to remove.
Jul 19, 2014, 02:15 PM
Dont forget to remove the lead in the nose of the square CF tube.
Jul 19, 2014, 03:41 PM
Lead from the nose inside the CF tube.
Dont know how heavy it was before drilling it out. Maybe 25 gramm. Length 4cm.
Jul 19, 2014, 03:49 PM
How much flight time can i expect with a 1600mah 2s and stock setup with the HK SS?
Jul 19, 2014, 04:26 PM
With 3S and 1300mah doing aerobatics 7-8 min all depending on flight style.
Normal flying much more flight time.
Jul 29, 2014, 04:11 AM
CrashingDutchman's Avatar
The slowstick at Hobbyking is on offer now for US$ 69.99.
Get it while it lasts, it is part of their super sale!
Jul 29, 2014, 06:51 AM
Ok question. Can the stock slow stick handle 3s packs???
Jul 29, 2014, 08:38 AM
I know some people fly it with 3S, but it seems to become nose heavy then. I also have seen people mentioning that there is a piece of led hidden somewhere in the nose that you have to remove. Good packs are 3S 2200mAh
Jul 29, 2014, 10:51 AM
Look at my post#68.
Jul 29, 2014, 11:01 AM
Originally Posted by tritan
Look at my post#68.
I did .. that's why I asked. did you excange the ESC to something better?
Jul 29, 2014, 02:39 PM
From previous page (4), my post #56:
"About 650 grams.
The prop included is a 10x4,5.
I use 3S & 1300mah with included motor and prop for ARF and can do aerobatic , very, very fun to fly this HK SS."
As I bought it ARF not PnP I installed a 30A ESC I had in a box.
No problems with nose heavy, actually I think a 3S & 1300 batt is perfect for balance, power and flying time.
Jul 29, 2014, 04:31 PM
that's great I missed it . thanks
Build Log Slow Stick Not: Pylon & Pattern Slow Stick Otto Dieffenbach Foamies (Kits) 12 Feb 23, 2015 02:51 PM
Discussion Slow V or Slow Stick? IWC Beginner Training Area (Aircraft-Electric) 7 Feb 07, 2013 08:19 PM
New Product From Slow Stick AP to Slow Stick FPV Qrome Aerial Photography 4 Aug 24, 2009 12:24 PM
Discussion From Slow Stick to Pro Stick Real Ira Aerial Photography 15 Mar 21, 2008 12:23 AM
Gallery AP Slow Stick - SLOW landing ProBroJoe Your Plane Photos 0 Oct 20, 2005 09:40 AM
