Jan 28, 2017, 10:26 PM
earlytide's Avatar
Originally Posted by hard line
I'm about to build mine. I expect to build it to spec except strength upgrades for the stick joiner and the wing joiner. Is there a purpose to the notch in the center of the ply wing joiner? I'm thinking of adding a thin carbon doubler to the joiner and if not needed, go right over that notch.
I saw a video on utube where they took a nylon bolt that just fit in the carbon fiber tube and cut the head off, bent to the dihedral of the plywood joiner, and hot glued it together during assembly. I had already assembled mine but it sounds like a good idea.
Earl
Jan 28, 2017, 10:45 PM
pull up -- PULL UP!!!
Thanks, but actually I finished mine today. The stick connection was beefed with an internal carbon tube and I left the plastic sleeve on as well. But everything glued instead of bolted. (5g)
I took 8" of thin wall stainless steel tubing, bent to the dihedral angle and ran it up both spar tubes. (8g)
Lastly took a length of .020 stainless steel spring wire and glued it around the perimeter of the ply wing joiner so it can't break in the center. (1g)
That's a total weight gain of 1/2 oz -- I think well spent.
Jan 29, 2017, 12:22 PM
earlytide's Avatar
I agree, and the tubing is probably lighter and stronger than the nylon bolt.
Earl
Jan 29, 2017, 03:22 PM
I think nylon isn't stiff enough to protect the ply joiner. It is plastic after all and will just let the joiner take all the load until it breaks. Then the nylon may or may not keep the wing from folding.
Maiden done. I thought it might be nose heavy at 90mm, but it trimmed out with a little down-elevator. I guess that could mean it's a little tail heavy or could also mean it needs more down thrust. It looks like it has some, but I didn't measure how much. I'll have to do a dive test. Only other issue was the rudder linkage squeeks like a barn door. I think the pushrod wire is too tightly fit in the horn. I'll get after it. But a nice flyer -- I'm happy with the result.
Jan 29, 2017, 07:43 PM
earlytide's Avatar
Good to hear it. Keep us updated on your final numbers and how you got there.
Earl
Jan 30, 2017, 01:36 AM
Eternal beginner
Rollmops67's Avatar
Hello Hard Line.
Look at this post, you will see how I reinforced my wings with duct tape (with fiberglass threads in it).
These days my Slow Stick has 90 flights, and the wing joint is still holding well, albeit I fly sometimes in a "harsh" manner.
Roland
Jan 31, 2017, 12:48 PM
Second day of flights. Ran a same-size drill bit through the horn hole, and the squeeking went away. I think the hole was the right size but maybe not quite round. Anemometer said 7mph, but it wasn't a problem. I think with a little more time I'll be comfortable in 10mph. My 1300 3S read 3.8VPC after 7 minutes of flying. Will probably go 8 or 9. Haven't done anything yet to reduce the climb with throttle. Still assuming it's thrust angle. I did confirm the stock mount is set for down thrust, but maybe not enough I guess.
Jan 31, 2017, 02:34 PM
R. Nordeck's Avatar
So today I finally maidened my HK SS. Success w/ two 6 min flights.
Notes: 29 F. w/ wind - 6mph N.; flew off snow packed dirt Rd @ home; 90 mm CG was way too nose heavy & all clicks up trim not enough; 2nd flight w/ 100 mm CG & A-OK with only a few clicks up to trim & few clicks right ail; used 3S -1300mah & calculates to 8 min flight time; flys w/ wide speed range f/ very slow walking speed at barely any throttle to way fast & vertical climb out at WFO!
I really like it & cautiously maybe, almost ready to try it w/ the FPV as soon as find spotter & another 30 Deg. Day !!
Jan 31, 2017, 03:19 PM
How odd that we're both at 90mm and yours requires a lot of uptrim and mine required a lot of downtrim.
Jan 31, 2017, 05:27 PM
R. Nordeck's Avatar
That is some strange; I remeasured my final / current CG & it's dead on 100mm, where it flew really well. Maybe because our air here in WY is too thin to support lift
Jan 31, 2017, 06:23 PM
Flight trim is a function of both CG and thrust angle. While 90mm works for me now, if I lower the thrust angle I may want to push the CG further back. A dive test will tell me, but what with inexperience with the plane and marginal weather, I haven't done it yet. It's a fun flier now, so I'm in no hurry to "fix" it.
EDIT -- It straight-lines a dive test both half throttle and unpowered. I guess I'll leave it alone for now.
Build Log Slow Stick Not: Pylon & Pattern Slow Stick Otto Dieffenbach Foamies (Kits) 12 Feb 23, 2015 01:51 PM
Discussion Slow V or Slow Stick? IWC Beginner Training Area (Aircraft-Electric) 7 Feb 07, 2013 07:19 PM
New Product From Slow Stick AP to Slow Stick FPV Qrome Aerial Photography 4 Aug 24, 2009 11:24 AM
Discussion From Slow Stick to Pro Stick Real Ira Aerial Photography 15 Mar 20, 2008 11:23 PM
Gallery AP Slow Stick - SLOW landing ProBroJoe Your Plane Photos 0 Oct 20, 2005 08:40 AM
