Aug 29, 2013, 05:40 PM
Pixhawk from 3D Robotics and PX4
Anouncement:
http://diydrones.com/profiles/blogs/...-user-friendly
Features
32 bit ARM Cortex M4 Processor running NuttX RTOS
14 PWM / Servo outputs (8 with failsafe and manual override, 6 auxiliary,
high-power compatible)
Abundant connectivity options for additional peripherals (UART, I2C, CAN)
Integrated backup system for in-flight recovery and manual override with
dedicated processor and stand-alone power supply
Backup system integrates mixing, providing consistent autopilot and manual
override mixing modes
Redundant power supply inputs and automatic failover
External safety switch
Multicolor LED main visual indicator
High-power, multi-tone piezo audio indicator
microSD card for long-time high-rate logging
Specifications
32bit STM32F427 Cortex M4 core with FPU
168 MHz
256 KB RAM
2 MB Flash
32 bit STM32F103 failsafe co-processor
ST Micro L3GD20H 16 bit gyroscope
ST Micro LSM303D 14 bit accelerometer / magnetometer
MEAS MS5611 barometer
Interfaces
5x UART (serial ports), one high-power capable, 2x with HW flow control
2xCAN
Spektrum DSM / DSM2 / DSM-X Satellite compatible input
Futaba S.BUS compatible input and output
PPM sum signal
RSSI (PWM or voltage) input
I2C
SPI
3.3 and 6.6V ADC inputs
External microUSB port
Power System and Protection
Ideal diode controller with automatic failover
Servo rail high-power (7V) and high-current ready
All peripheral outputs over-current protected, all inputs ESD protected
Monitoring of system and servo rails, over current status monitoring of peripherals
Dimensions
Weight: 38g (1.31oz)
Width: 50mm (1.96")
Thickness: 15.5mm (.613")
Length: 81.5mm (3.21")
Aug 29, 2013, 07:40 PM
Interesting
Sep 01, 2013, 07:34 AM
R_Lefebvre's Avatar
Bump. This fell off the main page pretty quick. Too many DJI Flyaway threads.
Sep 01, 2013, 08:15 AM
the reason not to use apm stuff are the flyaways.
have been running multiple times.
Sep 01, 2013, 12:56 PM
DVE
DVE
Its interesting about:
Why new design?
Are they better than popular MPU6000/6050?
Sep 03, 2013, 07:13 AM
R_Lefebvre's Avatar
Pretty rare now, and only when the user hasn't set it up properly.
Sep 03, 2013, 08:07 AM
Launch the drones ...
Tempting, but where's the vibration suppressor?
Was hoping it would have internal vibration dampeners like the NAZA has. Doesn't seem to.
Is there an approved off-the-shelf vibration dampener for this FC?
Or do we roll our own, again, like we did with the APM?
Sep 03, 2013, 08:11 AM
UNPLUG!
criccio's Avatar
Just an FYI, any and all questions that can possibly be asked already have been in linked article in the OP. Yeah its 23+ pages but the questions are being answered by the designers/developers and Chris Anderson himself.
Just an FYI so you're all not asking questions here and no one is answering them.
Sep 03, 2013, 12:16 PM
R_Lefebvre's Avatar
Tim, you're right, there is no vibration damping built in. However, early indications are that vibration will be well filtered in the code anyway. As long as your machine isn't vibration too much, it might require nothing more than some simple two-sided foam tape.
Previously we were sampling at 200 Hz and using a simple averaging filter. Pixhawk will sample at 1000Hz and use a more sophisticated Butterworth filter.
Sep 03, 2013, 01:00 PM
DVE
DVE
3DR products are using low-level market segment, thats a pity. So, no compass stand (it appears only in latest APM, btw), no internal dampers, etc. And the situation with sensors looks also strange.
I also will be glad to see Arducopter-compatible high quality controller
Sep 03, 2013, 03:48 PM
R_Lefebvre's Avatar
The proof is in the pudding.
Sep 03, 2013, 04:44 PM
good but we need to wait long time to see a real improvement vs original apm
Oct 13, 2013, 02:40 PM
Currently in Nairobi, Kenya
Willie's Avatar
Where can I find this information please?
Oct 17, 2013, 05:31 PM
Looks like no support for traditional PWM receivers, which is really a bummer. In the comments of one blog post one employee said they plan on offering an encoder eventually. Does anyone know if these exist already?
Oct 17, 2013, 05:35 PM
UNPLUG!
criccio's Avatar
They already sell one.
http://store.3drobotics.com/products...oder-version-2
Then again why anyone would want to run more than one cable from the receiver to FC is beyond my comprehension, especially given how cheap modern receivers are. I'm glad they didn't include a whole bank of headers for old school PWM receivers, that will only serve to make it bigger and not help push the hobby forward. A FrSky D4R-II PPM and Telemetry enabled receiver is what, $20? I have a tricopter I've taken out to almost 2 kilometers on one.
Discussion Submit your robot and win $1,000 in robot prizes from GoRobotics gallamine UAV - Unmanned Aerial Vehicles 1 Feb 17, 2016 12:08 AM
Found 3D Robotics AMP 2.5 setup, want to trade for DX-8 mode 2or better TX nhaddock Aircraft - Electric - Multirotor (FS/W) 2 Jul 19, 2013 11:32 PM
Sold 3D Robotics AMP 2.5 setup, want to trade for Spectrum compatible Transmiter. nhaddock FPV Equipment (FS/W) 4 Jul 17, 2013 11:29 AM
Found 3D Robotics AMP 2.5 setup, want to trade for DX-8 mode 2or better TX nhaddock Aircraft - General - Radio Equipment (FS/W) 0 Jul 16, 2013 08:05 PM
Discussion PX4 by Pixhawk nyc863 UAV - Unmanned Aerial Vehicles 0 Jul 26, 2012 09:42 PM
