This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Aug 18, 2013, 03:11 AM
Jack Crossfire's Avatar
Horns & waveforms
You can make a waveguide out of steel & solder.
That gets a decent shotgun pattern, but nothing like control tower radar. It's not grounded or connected to the antenna.
With 17x amplification from the MAX412, it makes the expected waveform. The 1st problem is getting the proper VCO sweeping curve, which is not linear. The current curve makes lots of ghosts & spreads reflections over too many frequencies to detect anything.
The next problem is getting enough ADC resolution to handle the extremely wide dynamic range. You can't just analyze the section under 50mV. The entire sweep range is needed.
Sold Futaba Servo Horn Drill Gauge/HD Servo Horns wolfcbr2003 Aircraft - General - Radio Equipment (FS/W) 1 Apr 12, 2013 06:29 AM
Help! Output Waveform Of Reciever And The Bldc Controller CLEMENT DIY Electronics 4 Feb 01, 2010 08:08 AM
Adding an offset to an AC waveform Neil Stainton DIY Electronics 9 Dec 17, 2004 06:31 PM
Brushless Motor Waveform Neil Stainton Power Systems 10 Jun 26, 2003 04:13 AM
Output waveform to coil actuator lkykenneth Scratchbuilt Indoor and Micro Models 8 Jun 21, 2003 06:23 PM
