This thread is privately moderated by Turner2, who may elect to delete unwanted replies.
Aug 14, 2013, 02:30 PM
DX7 Programing - Ultimate Spoileron/Flaperon, Crow, 3 Position Flap Mix
I've been working with the DX7 for a couple years. I've sought out programing for dual aileron servos and dual flap servos while giving the maximum functionality. I hoped to be able to have three position flaps while still being able to use aileron differential and perhaps have some independent spoileron/flaperon function.
I've got some different programs that I have worked out. Some evolved from programs offered by Spektrum employees and I will give due credit where I can. I will keep this closed till I get all my current programs posted and then open it up for comment and discussion.
DX7 - Flap 1
Dual Aileron/Dual 3 Position Flaps - No Aileron Differential - No Spoileron/Flaperon
This was originally from Mike McConville. It was for a single flap servo setup used in the E-Flite RV-9 and T-34. I added P-Mix 6 for the second flap servo and the Gear to Gear mix to inhibit the gear switch.
Right Aileron servo goes to Aileron channel - Left Aile servo goes to AUX 2
Right flap servo to Flap channel - Left Flap to Gear channel
SYSTEM SETUP
[Input Select]
AUX2: INH
AUX2 TRIM: INH
FLAP: SYSTEM
FLAP TRIM: INH or ACT - Active trim moves flaps equally via Flap Rocker
[WING TYPE]
FLAPERON: OFF - Off cancels the differential screen from function mode
V-TAIL: OFF
DELTA: OFF
FUNCTION MODE
[FLAP SYS.]
------------------ FLAP ----------- ELEV
NORM ------ UP 100% ----------- 0 ----- Adjust Flap % according to your needs. If you want some elevator mixed in, do it here
MID ------------------ 0% ----------- 0
LAND ------- DN 100% ----------- 0
AUTO: INH
Program Mixes
----------------------------- CHANNEL ------ SW --- +RATE -- −RATE ------ OFFSET
[PROG. MIX 1] ---- GEAR ⪫ GEAR ---- ON --- −100% --- −100% ---------- -0- -------- Inhibits Gear Switch
[PROG. MIX 5] ----- AILE ⪫ AUX 2 ----- ON --- +100% --- +100% ---------- -0- -------- For 2nd Aileron Servo
[PROG. MIX 6] ----- FLAP ⪫ GEAR ---- ON --- +100% --- +100% ---------- -0- -------- For 2nd Flap Servo
Discussion Older DX7 flaps programming 3 servo wing stemo99 Radios 8 Feb 28, 2013 02:50 PM
Discussion Help! DX7 and AR6000, mixing for flaps and ailerons warhead_71 Radios 9 May 20, 2010 10:52 AM
Discussion DX7 - Flaps, Ailerons, 4 servos, mixing. Kurts Radios 2 Oct 17, 2008 09:23 AM
Help! DX7 Flap to Aux2 mixing rogerchr Radios 1 Aug 04, 2007 06:07 PM
