This thread is privately moderated by Turner2, who may elect to delete unwanted replies.
Aug 14, 2013, 02:29 PM
DX7 Programing - Flap Mix 2
DX7 - Flap 2
Dual Aileron/Dual 3 Position Flaps - No Aileron Differential - No Spoileron/Flaperon
Right Aileron servo goes to Aileron channel - Left Aile servo goes to Flap channel
Right flap servo to AUX 2 - Left Flap to Gear channel
SYSTEM SETUP
[Input Select]
AUX2: INH
AUX2 TRIM: INH
FLAP: System
FLAP TRIM: INH or ACT - Active trim moves flaps equally via Flap Rocker
[WING TYPE]
FLAPERON: OFF - Off cancels the differential screen from function mode
V-TAIL: OFF
DELTA: OFF
FUNCTION MODE
[FLAP SYS.]
------------------ FLAP ----------- ELEV
NORM ------ UP 100% ----------- 0 ----- Adjust Flap % according to your needs. If you want some elevator mixed in, do it here
MID ------------------ 0% ----------- 0
LAND ------- DN 100% ----------- 0
AUTO: INH
Program Mixes
----------------------------- CHANNEL ------ SW --- +RATE -- −RATE ------ OFFSET
[PROG. MIX 1] ---- GEAR ⪫ GEAR ---- ON --- −100% --- −100% -------- -0- -------- Inhibits Gear Switch
[PROG. MIX 5] ---- FLAP ⪫ AUX2 ------ ON --- +100% --- +100% -------- -0- -------- for 2nd Flap Servo
[PROG. MIX 6] ----- AILE ⪫ GEAR ----- ON --- +100% --- +100% -------- -0- -------- for 2nd Aileron Servo
Discussion Older DX7 flaps programming 3 servo wing stemo99 Radios 8 Feb 28, 2013 02:50 PM
Question DX7 Flap mix davidwp56 Australia 8 Jul 28, 2010 07:11 AM
Discussion Help! DX7 and AR6000, mixing for flaps and ailerons warhead_71 Radios 9 May 20, 2010 10:52 AM
Discussion DX7 - Flaps, Ailerons, 4 servos, mixing. Kurts Radios 2 Oct 17, 2008 09:23 AM
Help! DX7 Flap to Aux2 mixing rogerchr Radios 1 Aug 04, 2007 06:07 PM
