This thread is privately moderated by Turner2, who may elect to delete unwanted replies.
Aug 14, 2013, 02:28 PM
DX7 Programing - Flap 3
DX7 - Flap 3
Dual Ailerons W/Differential - Dual 3 Position Flaps
This and the following programs use Flaperon ON. Flaperon ON automatically mixes aileron channel to Flap/Aux 1 channel.
My ultimate goal was to have full use of the flaperon/spoileron programing with the Flap System screen and aileron differential with the Differential screen plus fully independent three position flaps hopefully allowing different combinations of Crow and/or flaperons with flaps.
Right Aileron servo goes to Aileron channel - Left Aile servo goes to Flap/Aux1 channel
Right flap servo to AUX 2 - Left Flap to Gear channel
SYSTEM SETUP
[Input Select]
AUX2: 3P Switch
AUX2 TRIM: ACT/INH - your choice - Active adjusts both flaps equally
FLAP: System or INH - System allows Flaperon/Spoileron with Flap 3P switch and with Flap Rocker.
INH isolates 3P switch to flaps and disables the Flap System screen. You still have Spoileron/Flaperon function with the Flap Trim Rocker.
FLAP TRIM: ACT - Active trim gives flaperons/spoilerons with the Flap Rocker. This only effects ailerons.
[WING TYPE]
FLAPERON: ON - Enables the Differential screen in function mode
V-TAIL: OFF
DELTA: OFF
FUNCTION MODE
[FLAP SYS.]
Zeros in flap column gives no aileron movement from flap switch.
Positive or negative values give spoilerons or flaperons from flap switch.
Flap travel must be adjusted via mechanical setup and via the Travel Adjust and Sub Trim screens.
You can set elevator compensation for flaps here.
-------------- FLAP ------- ELEV
NORM ------ 0% ----------- 0 ----
MID ---------- 0% ----------- 0 ----
LAND ------- 0% ----------- 0 ----
AUTO: INH
[DIFFERENTIAL]
FLAPERON
DIFF. - Set % for desired aileron differential
Program Mixes
----------------------------- CHANNEL ------ SW --- +RATE -- −RATE ------ OFFSET
[PROG. MIX 1] ---- GEAR ⪫ GEAR ---- ON --- −100% --- −100% -------- -0- --- Inhibits Gear Switch
[PROG. MIX 5] ---- AUX 2 ⪫ GEAR ---- ON --- +100% --- +100% -------- -0- --- Flap Servos on AUX2 and Gear
Discussion Older DX7 flaps programming 3 servo wing stemo99 Radios 8 Feb 28, 2013 02:50 PM
Question DX7 Programming with Seperate Flaps UnPossible Radios 7 Jun 27, 2009 05:24 AM
Discussion Programming instructions for Ultra Stick 40 quad flaps using DX7 flytivoer Radios 8 Mar 09, 2009 02:07 PM
Help! DX7 Program Flap Deployment Speed? muckie Radios 7 Mar 16, 2008 11:13 AM
Discussion DX7 Programming help - Flaps steve1814 Radios 1 Feb 29, 2008 08:13 PM
