GWS WIN WIND is comming! - Page 3 - RC Groups
Jan 23, 2009, 03:43 PM
sebsoupe's Avatar
Originally Posted by GWS CHEN
Hi Sebsoupe,
Just click at the photo of Win Wind from this link, http://www.gwsus.com/english/service...ane_manual.htm
Chen
Thank you very much Chen!
I will print the manual to study it before receiving my win wind kit...
I'm going to write a report in a french RC newspaper for french customers...
Bye,
sebsoupe
Jan 23, 2009, 11:40 PM
Hi Sebsoupe,
You're welcome !
Your coming report will be highly appreciated. Thanks
Chen
Jan 24, 2009, 11:04 PM
Houng-wen Lin
GWS4CEO's Avatar
Originally Posted by Tommy D
From the above....
Recommended Propeller 9x6~10x7
How in the world are you going to get a 12" prop on this thing Mr Lin?
The reason to use short props was consider less crash damage to prop during take off and landing.
Jan 26, 2009, 11:23 PM
Hooper, full throttle!
Tommy D's Avatar
Not to mention it's a tricycle landing gear. Which is no consequence when flying a fuel powered model that spins a small prop in the 1st place.
Jan 27, 2009, 10:21 AM
Houng-wen Lin
GWS4CEO's Avatar
May be can use 3 blades props to get enough load, yet smaller dia.
GWS EP1060X3 or EP1170X3?
Jan 27, 2009, 11:08 AM
Tommy D's Avatar
Unsubscribed
Jan 27, 2009, 02:55 PM
Houng-wen Lin
GWS4CEO's Avatar
Unsubscribed
Sorry! Did I missunderstanding your point?
Jan 30, 2009, 09:00 PM
EDF rules... :)
AirX's Avatar
Tommy,
I have been flying a large outrunner(equivalent of a .40) on a similar plane, I use a 10 x 10 prop which loads the motor similarly to a 12 x 8.
Eric B.
Mar 05, 2009, 04:11 PM
sebsoupe's Avatar
Hello!
I have received the Win Wind tonight !!!
it's a very nice plane...
I need some epoxy glue, and a motor mount for my brushless
Bye,
sebsoupe
Mar 05, 2009, 11:32 PM
Hi Sebastien,
Would you post more pictures and your findings. You might be the first pilot who converts Win Wind into electrical bird.
Chen
Mar 06, 2009, 09:36 AM
sebsoupe's Avatar
Hi Sebastien,
Chen
Hello!
I'm going to write a report for a french RC magazine,
and yes I will add pictures here of the building...
Now the wing is done, I need more time to finish the fuse and to mount the motor...
Bye
sebsoupe
Mar 06, 2009, 10:01 AM
sebsoupe's Avatar
Chen,
there is nothing in the book for the mount of the canopy and the motor cowl???
are they glued or anything else???
Bye
sebsoupe
Mar 06, 2009, 11:46 AM
Hi Sebastien,
Normally you have to glue the canopy, and screw the cowl on the fuselage. You do not have to cut the side of the cowl for the engine cylinder but you still have to try add more air cooling for the motor, lipo and ESC.
Chen
Mar 06, 2009, 12:56 PM
sebsoupe's Avatar
with CA directly on the wing ???...
yes, I will enlarge the front hole of the cowl to let enter more fresh air into the cowl, and i will make an other hole under the fuse to let the air exit of the fuse...
I'm trying to find a nice motor mount for the 3020/8T, like this one "hyperion 30 motor mount" but the diameter of the base (65mm) is a little to wide for the Win Wind fuse (60mm large)...
keep searching!
Bye,
sebsoupe
PS : is it OK to use Naro Super D ??? (even with the problem mentionned here), else I've got 2 servos S3N STD and 2 S3T STD
Mar 06, 2009, 09:19 PM
Hi Sebastien,
CA, epoxy and GWS glue all work well on this, it's not foam wing, it's balsa sheets + film.
It's OK to use Naro Super D, the problem mentioned was that "Head Locking Gyro'' made some of the motor inside of this servo unhappy. You have to work on the plywood servo mount as it was cut for standard size servos, ie. GWS S03T or S03N.
Chen
