Aug 10, 2013, 12:28 PM
I make metal smaller.
Endlesslag's Avatar
Byron Beechcraft Staggerwing electric conversion
Hi all,
I have a Byron Beechcraft Staggerwing that currently comes in at 30lbs AUW and is running a quadra 40 gasoline engine, which is rated for 3hp/2.2kw.
This engine is giving me a headache, and the airframe is getting old and can't take much more pounding on it, so i was thinking of electric converting it. I'm thinking a system around 3000 watts or so will give a nice performance boost, while remaining scale and not giving me an opportunity to blow the wings off. The biggest electric system I have set up to date was about 1500W, so I was hoping I could get some help with doing this one.
I'd like to keep it somewhat cheap, but I don't mind spending some extra bucks on good motors or ESCs if I have to.
To keep the CG from being an issue, I'd like to keep the system about the same weight as the engine right now- somewhere in the range of 4-6lbs, spinning a 17-21 inch prop. Also, 8s or 12s is preferred, as I have a lot of 4s 4000 batteries...8s2p or 12s2p could be a good way to go.
Thanks ahead of time,
Nick
Aug 12, 2013, 01:20 PM
Check this one out if you're wanting about the same power.
http://www.advantagehobby.com/68352/...4795/?pcat=351
The next biggest RImfire is the 50cc model, which for a 30# model is another option.
http://www.advantagehobby.com/110224...4800/?pcat=351
For Sale Top Flight Beechcraft G17S Staggerwing w/retracts bromschwig Aircraft - Fuel - Airplanes (FS/W) 7 Feb 05, 2017 12:10 PM
Discussion Byron Beechcraft Staggerwing Endlesslag Scale Fuel Planes 176 Sep 03, 2013 05:42 AM
Sold 1/5 scale Byron Beechcraft Staggerwing tenacious101010 Aircraft - Electric - Airplanes (FS/W) 0 Jan 01, 2013 04:05 PM
Sold BYRON ORIGINALS BEECHCRAFT STAGGERWING Kit NIB W/RETRACTS $750.00 FREE SHIPPED!! stevster Aircraft - Fuel - Airplanes (FS/W) 1 Feb 25, 2012 06:58 PM
