Aug 08, 2013, 02:40 PM
Castle Support
Clintstone's Avatar
Mini-HowTo
Castle and Skookum Calibration Notes...
Skookum Castle Calibration Instructions from Brandon Taylor
Make sure that when you set high and low throttle in the ESC that you are in electric gov mode in the
sk540 when you do it. When you're in no gov mode on the 540 and click over to electric gov mode,
the throttle endpoints stored within the Skookum can change.
Below are the steps to set the 540 Gov in CC ESC;
1. Radio throttle endpoints all the way up
2. Gov OFF in SK540
3. Set High throttle in 540
4. Set Low throttle in 540
5. Unplug lcd programmer or usb
6. Proceed to program CC ESC endpoints as normal
7. Plug in LCD or usb
8. Set High Throttle in 540
9. Set Low throttle in 540
10. Click into E Gov mode in 540
Let us know how it goes.
Brandon
Skookum Robotics
Special thanks to Brandon at Skookum Robotics...
May 10, 2019, 10:17 AM
Heli Mad
stevebarrow's Avatar
Doesn't work with SK540 Castle 120HV Edge ESC and DX9. Tried it with fixed endpoints, aircraft and external gov modes. Simply won't calibrate. I am on the verge of trashing the SK540 and getting another FBL unit.
The ESC will calibrate with a receiver only setup.
Mini-HowTo Castle Quick Tip: Throttle Calibration Part 1 of 2 Clintstone Castle Creations 45 Dec 03, 2013 11:37 PM
Help! castle ice lite 50 throttle calibration swampflyer 3D Flying 5 Jun 01, 2013 12:39 PM
Discussion Castle ESC throttle calibration question. cookci Castle Creations 1 Mar 13, 2013 05:06 AM
Sold New Skookum SK-720, Castle Ice 100 w/Pro BEC, Spektrum DX7 panzerdivision Aircraft - Electric - Helis (FS/W) 0 Sep 24, 2011 01:17 PM
Mini-HowTo Castle Quick Tip: Auto-Rotation Calibration Part 2 of 2*Video* Clintstone Castle Creations 45 Oct 22, 2010 08:52 PM
