This thread is privately moderated by Thermal Hobby, who may elect to delete unwanted replies.
Aug 03, 2013, 11:54 AM
Shake your Foamy!
SHAKE TESTING YOUR MODEL
Get the most out of your model. If you are skeptical about the airworthiness of your model why not give it a shake? This will help you see what could go wrong while in the air as well as if anything is moving around in the compartments that could throw off the CG or even moving wires on the outside that could cause drag. Take your model with the canopy on and grip the model so that it won't fall, but also support the structure. Move the model rapidly as you would expect to see it flying as it is making maneuvers in the air. Tip the model in on a horizontal plane as to pitch the nose up and down rapidly, do the same method while the model is upside and sideways. Do rolls loops etc, with it even if it is incapable of performing the tricks. If your model has a canopy, This will test if you have a good canopy latch also. You shouldn't feel anything sliding around or moving at all inside or outside of it. If you do notice movement of even the slightest try to secure the object down better with velcro, hot glue or straps. Be careful though stuffing it with too much latex foam or soft cloth like objects could cause some air flow problems around the electronics Doing these steps before a flight only raises the performance and fly-ability enjoyment you will have with your model from the air to landing.
Discussion Show us your large Foamies! NCNeal Foamies (Scratchbuilt) 43 Jul 17, 2013 05:09 PM
Discussion Show your small Foamies!! Swamppxxl Foamies (Scratchbuilt) 0 Jul 06, 2013 08:20 AM
Discussion home made parachutes for your foamies samwei1950 Foamies (Scratchbuilt) 5 May 25, 2013 05:14 AM
Discussion a ladder for your scratchbuilt foamies samwei1950 Foamies (Scratchbuilt) 5 Apr 14, 2013 03:09 AM
Discussion how do you store your foamies? swampflyer 3D Foamies 16 Feb 09, 2013 01:24 PM
