Nov 23, 2019, 11:27 AM
ode guy's Avatar
I made a battery "sled" from 1/8" plywood...1.5"wide by 10"long. The front hooks under a lip that I installed under the motor mount. Now I can place my battery anywhere I want.... with no need to add dead weight to balance.
Nov 26, 2019, 03:10 PM
Has anyone converted one of these as a STOL/backcountry plane? I'm looking for scale STOL performance. The full scale PA-20 Pacer is popular for backcountry use. I think she'd look fantastic on a set of tundra tires. Plus, having the option to swap the stock wheels and wheel pants back on would make this a very versatile model.
Nov 26, 2019, 03:30 PM
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
The plane is pretty heavy as is.
Big fat tundra tires would definitely help with bounces but in terms of STOL, it would need a better power/weight ratio.
Nov 30, 2019, 10:56 PM
DFS#000178
Rampage's Avatar
Order's in for mine. Ordered it with the spinner because it looks 'real nice. I'm going to try to mount up this Power 15 I've got and if it'll go in without mods, great. If not I'll order up a 10.
Figured what the hell. The last of the scale EFlite balsa planes. Better get one before they axe it too.
Dec 08, 2019, 07:44 AM
[QUOTE=Rampage;43279595]Order's in for mine. Ordered it with the spinner because it looks 'real nice. I'm going to try to mount up this Power 15 I've got and if it'll go in without mods, great. If not I'll order up a 10.
Figured what the hell. The last of the scale EFlite balsa planes. Better get one before they axe it too.[/QUOI\
I just order one from Tower, I will be interested to know if your 15 will fit since I will probably go with that to avoid putting to much dead weight up front.
Frank
Dec 08, 2019, 09:13 AM
I can fix that!
doug.wagner's Avatar
I used a Turnigy SK3 3536 1200kv motor.
https://hobbyking.com/en_us/turnigy-...html?wrh_pdp=2
It has an excess of power, (just the way I like it) and I was able to achieve balance on the CoG, without adding weight.
I love flying this plane!
Dec 08, 2019, 01:07 PM
Thanks Doug for the info. is that a 10 size equivalent or 15? What prop and what Lipo, 3s or 4s?
Thank you ,
Frank
Dec 08, 2019, 02:01 PM
ode guy's Avatar
I went with a Power 25 left over from a re-kit. Had to shorten the motor mount box a bit.
With a 6.5oz 3s 2200 pushed almost under the motor, it balanced without adding ballast. Came in at 3.0lbs.
My son maidened it yesterday...much better pilot than I am! Great flyer! Gonna be a good teacher for me. Found the rudder to be very powerful.
Dec 08, 2019, 04:32 PM
Thank you, sounds like a good plane. I fly mostly warbirds but a have a soft spot for classic civilian airplanes .
Dec 08, 2019, 10:25 PM
I can fix that!
Thank you ,
Frank
Sorry Frank, I don't come from a ICE background, so I don't think in those 10, 15 or 25 equivalent motor sizes. (I'm assuming that comes from the fuel powered days, and refers to a .10", or .15" displacement size?)
I only pay attention to kv rating, and wattage, and this motor supposedly can put out 500 watts.
I'm pretty sure I put an Aerodrive 11X6 prop on there.
I fly with a 4S 3000 mAh battery.
Dec 09, 2019, 06:17 AM
Okay Thanks Doug , think I will try that motor and prop combo.
Regards,
Frank
Feb 12, 2020, 12:30 AM
Radjet 120 Mph
E-flite PA-20 Pacer 10 Nitro conversion?
I just ordered a E-flite PA-20 Pacer 10e ARF and would like to use an O.S Nitro engine. I read somewhere the electric E-Flight Equivalent is a 10-size glow engine. I have a OS Max .46AX, would that be to big for this 51" wingspan plane?
Feb 12, 2020, 10:36 AM
That's a big engine for this plane.
It requires a bit of nose weight but a .46 might be overreaching. Maybe a .25 at most.
See this post:
https://www.rcgroups.com/forums/show...&postcount=995
https://www.rcgroups.com/forums/show...postcount=1000
Feb 12, 2020, 03:30 PM
Radjet 120 Mph
See this post:
Ok thank you, that's what I expected. Ill order a .25
Mar 03, 2020, 10:47 AM
Hi Doug,
I`m in the process of setting this plane up and was wondering if you programed any differential into the ailerons ?
Frank
Sold E-Flite Ultimate 20-300 10e Long Island Local Pickup Only LICobra Aircraft - Electric - Airplanes (FS/W) 5 Apr 06, 2013 05:24 AM
Sold Stearman PT-17 15e ARF by E-flite Local in Philadelphia,PA Big Fran Aircraft - Electric - Airplanes (FS/W) 0 Jan 17, 2011 03:49 PM
Sold NIB E-Flite Ultimate 20-300 10e ARF plus electronics tsever00 Aircraft - Electric - Airplanes (FS/W) 6 Mar 28, 2009 10:11 PM
Discussion E-flite Ultimate 20-300 10e ARF Gonzo007 3D Flying 2 Apr 02, 2008 10:31 PM
