Thread Tools |
This thread is privately moderated by Esprit Model, who may elect to delete unwanted replies. |
Scroll down to: Step 8: Aileron Setup using the “Finding the true center” method That's how I do it, and it works quite well - you end up with very little difference if any at mid throws. |
I apologize in advance for the stupid question - under the "configuration" sub-menu within the "system" menu there is PPM output / connector setting. Is this only for when connecting an external device to the output connector in the radio? I ask, because mine is set to 8 positive, there is also the option off, etc. As I don't use an external module connected to the transmitter, can I switch this to off?
Hi,
Yes, there is a connector inside the transmitter, this setting sets the output format of that connector. In you case you can switch it off. Aaro Quote:
@wfield0455 - I figured the throttle percentage voice announcement thing completely by accident. For anyone interested, go to sounds of prop controls, add, pick your throttle channel, for mode select voice. Do not pick a file (that was my problem). To have the voice announcement associate throttle off with zero vs. -100%, put your throttle in the off position and push the function button under the "centr".
I think I know what you're saying, using the throttle cut feature won't allow you to manually initiate a cool down by moving the throttle stick all the way up with the throttle cut on. The way I worked around this was to use a logical switch for the throttle cut. The logical switch is a combination of my kill switch (Sc) and the throttle stick (P4) with P4 only on if X<98%. With this arrangement you can move the throttle to 100% with the kill switch on and the starter will engage, this works on my Kingtech and JetsMunt turbines.
Regards, |
Long time listener, first time caller. New Jeti user coming from another brand. I have watched a lot of videos and have been reading through a bunch of stuff on the web. Lots of good information out there. I am setting up my first plane which is a basic set up for an EDF. 1 Aileron, 1 Flap, Gear, normal tail and nose steering on a separate channel which is mixed to the rudder at 30% and goes to 100% on a spring loaded switch. Flaps are set up via flight modes on a 3 position switch and that seems to be working. Hoping to fly with the new equipment tomorrow. My stupid question is about the antennas on the RX which is a REX7. Is there an optimal geometry for them? Do they need to be at an angle or just straight out ok?
Thanks in advance. |
Thread Tools | |
Similar Threads | |||||
Sold | Turnigy programming card / servo / battery tester- t-rex 450 airplane tools set | helifreak592 | Aircraft - Electric - Helis (FS/W) | 0 | Apr 22, 2013 05:06 AM |
Help! | how do i program THROTTLE HOLD (airplane) in a DX8 | motor12 | Radios | 12 | Dec 31, 2012 06:27 PM |
Discussion | Align 35A ESC Airplane Programming Question | dnorm | Electric Plane Talk | 4 | Jan 11, 2007 11:18 AM |
Airplane design programs??? | RickC2009 | The Builders Workshop | 1 | Dec 21, 2004 09:57 PM |
