Jul 28, 2013, 04:14 PM
Question
Removing film covering from an ARF
If you want to do a re-cover, what is the best, simplest way to remove the factory film covering without damaging the underlying structure?
Jul 28, 2013, 04:23 PM
Wake up, feel pulse, be happy!
Piece's Avatar
Apply liberal heat with your iron or heat gun to melt/soften the adhesive and then just pull the old covering off. It might help to cut up the film over open areas before applying heat in order to give you smaller sections to work with.
Jul 28, 2013, 04:45 PM
Hobby King Hater
Kimber's Avatar
What he said, and save some of the pieces. There will be spots where the glue, pigment
stay. Just stick a piece of scrap on these spots and heat and it should come off, you may
need to repeat a time or two.
It takes time.. no rushing this process.
I have done several. I get the dirty jobs...
Jul 28, 2013, 04:51 PM
Thank you all!
Jul 29, 2013, 07:26 AM
DustBen's Avatar
Some lacquer thinner or acetone will help get the last bits of backing material off woods and metals.
Keep the solvents away from plastics and similar products
Jul 29, 2013, 09:45 AM
yank and bank!!
I gently peel it off then mechanically remove residue so the structures aren't exposed to harsh chemicals.... a sanding block and careful use of a dremel tool.
Jul 29, 2013, 10:56 AM
Ken Myers's Avatar
Regular masking tape can be used to cover dark areas of covering that are too hard to remove, if you are going to cover in a light color.
Jul 29, 2013, 11:24 AM
...missing the PE Slope Rebels
Flying Beagle's Avatar
hey Ken, howzit?
I was just doing a search on "covering removal"......I have a new Hangar9 Corsair that is itching to be converted to an F2G
thanks for the help guys
Jul 29, 2013, 02:46 PM
Redacted per NSA "suggestion"
dedStik's Avatar
This, heat gun slice anywhere there is not wood, peel off in pieces while applying heat, sanding may be required to remove some coloring and glue residues.
Question Can I remove the capacitor from an esc? Sandav Multirotor Drone Electronics 6 Jun 05, 2013 09:43 AM
Discussion Removing packing tape from covering cloud_9 The Builders Workshop 9 Mar 10, 2013 02:02 PM
Discussion Removal of covering film heat activated glue from solid surfaces? Masterpiece Painting and Finishing Tips 7 Sep 19, 2011 08:33 AM
Question Removing residue of covering film from a composite surface? Masterpiece Painting and Finishing Tips 5 May 24, 2009 05:44 AM
Discussion Any Tips on Removing Epoxy from Covering Film. jnm2512 Electric Plane Talk 5 Aug 28, 2006 12:32 AM
