Jul 28, 2013, 12:45 AM
Chad
TheOne420's Avatar
Build Log
Wooden FPV W/DJI F330 arms
I wanted to make this frame for the dji330 arms because I like the smaller agile quads for fun flying fpv and wanted something I could make cheap. I did a complete design from memory but it came out very close to the ov3rquad design. I guess I just really liked the look so I kept as close to it as possible but it will most likely be redesigned more than once in the future.
I just wanted to get a thread started that I could get input from some of you on what could make this design better.
enough of the BS here are some pics to get it started
Aug 14, 2013, 02:48 PM
Chad
TheOne420's Avatar
here is a pdf if anyone wants to cut a frame
I have staples print them on a single sheet so everything lines up right.
Aug 15, 2013, 06:50 AM
Do you know how much those arms weight?
Aug 15, 2013, 11:14 AM
twang's Avatar
6mm ply would be really heavy. You could try 3mm and may need some spacers on the sides for rigidity. It would be lighter
Aug 15, 2013, 11:38 PM
Great!
Aug 16, 2013, 12:27 AM
Chad
TheOne420's Avatar
The entire frame as is(4 x dji330 arms, screws and plates) weights in at 185grams
it is pretty strong not much flex but if you were to put a small piece half way up each side it would make the frame very solid.
I have no frame stiffeners(if that's what you call it) in my larger 570mm frame using the 450 arms and it uses the same 1/4 birch plywood. I get no flex when I fly it but I am flying it with a naza and gps so it is pretty tame not like my cc3d boards.
Aug 21, 2013, 02:02 PM
Looks nice. I wish I had access to such a saw?
Aug 21, 2013, 04:07 PM
Chad
TheOne420's Avatar
I can get different formats for the design so maybe someone out your way like cam could cnc you a frame.
Aug 21, 2013, 04:28 PM
Sent you a pm.
Aug 21, 2013, 05:34 PM
Chad
TheOne420's Avatar
here is a pic of the lengths for reference
Dec 15, 2013, 07:29 PM
Looks very nice
Dec 29, 2013, 09:17 PM
9W2DLR
Hi,
can you convert it to DXF? thanks!
Dec 29, 2013, 10:23 PM
Chad
TheOne420's Avatar
sure here you go.
What are your plans? wood or composite? I am interested in finding someone to cut me a frame from G10, carbon fiber or something similar if you have the ability send me a PM
Dec 29, 2013, 10:45 PM
9W2DLR
Thanks! FR4 or those PCB with copper backing usually been use by DIY electronics, I have plenty of them in my possession
Dec 29, 2013, 10:50 PM
Chad
TheOne420's Avatar
do you have a cnc? I would like this frame cut in the same material if you could do one for me and I can pay you for it.
Sold DJI S800 w Retracts w Zenmuse Z15 w Sony NEX-7, Vibration kit, Secraft Arms - $5,850 h8tow8 Aircraft - Electric - Multirotor (FS/W) 6 Jul 31, 2013 12:53 PM
Wanted DJI f330 arms templton89 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2013 07:37 PM
Sold Used DJI F330 + Extra Arms zestyzsauce Aircraft - Electric - Multirotor (FS/W) 0 Mar 25, 2013 08:01 PM
Cool DJI F330 DJI F330 Germany VS United Kingdom fung Multirotor Drone Talk 1 Jun 26, 2012 10:52 PM
