This thread is privately moderated by limmacslim, who may elect to delete unwanted replies.
Jul 24, 2013, 03:31 PM
limmacslim's Avatar
Marchetti SF-260
This is my Marchetti SF-260, It has a box type fuselage & NACA0013 wing, its based on drawings found at http://www.the-blueprints.com/. Mostly made from 3mm depron & powered by another rewound blue wonder, something like 2000kv pulling 18-19a from a 1000mah lipo on a not very well balanced 7x5 prop, 360g AUW.
It doesnt look it in the video but its actually a tiny bit quicker than our other higher kv park flier sized pusher jets & consistently edges away from them. Its not really my type of thing but thought I would have a go at a semi scale warbird type thing.
At times it feels like a baby to fly but has retained some characteristics I have read about regarding the full scale aircraft. In a stall it is not very well behaved, there is plenty of warning but it really needs the motor spinning to keep it in the air & only comfortably cruises at a relatively high throttle setting even though I went for a low-ish wing loading, someone else noted its either flying or falling & this model is pretty much the same.
Marchetti SF-260 depron RC aircraft (2 min 42 sec)
Jun 11, 2016, 02:00 AM
Hi im kiet, i will only share an event when i saw an sf260fh retracted its gears automatically, no one touch the lever of the gears since the pilot is only about to start their flight, i will only ask anyone from this group if they haven seen or experience the same event. Thank you guys
Discussion Siai Marchetti SF 260 3view with frames sfluck Foamies (Scratchbuilt) 4 Jun 19, 2015 09:23 PM
Wanted Nitroplanes SF 260 Marchetti ARF NoFlaps Aircraft - Fuel - Airplanes (FS/W) 1 Apr 22, 2012 07:29 PM
For Sale Composite ARF SIAI Marchetti SF-260 spookyeng Aircraft - Fuel - Airplanes (FS/W) 0 Mar 22, 2012 05:20 PM
Sold Siai Marchetti SF-260 plans Hemikiller Aircraft - Fuel - Airplanes (FS/W) 2 Jan 30, 2012 10:35 AM
