Jul 14, 2013, 07:06 PM
Wowplanes.com
awrightbrother's Avatar
Build Log
UFO aka FLYING SAUCER
Hello folks,
It's that time of the year in Florida when the sun is hot, the temp is high, and the humidity is something else. So it must be time to stay indoors and build. I feel a little scaled out designing and building scale models, so I decided to do something radically different than anything I have done before.
DESIGN, BUILD and FLY a "UFO" aka a "FLYING SAUCER".
Let's see where I end up with this baby.
It is going to be 35" in dia and about 7" tall at the apex. My goal is to keep it between 3 to 4 lbs AUW.
Fahim
I started with this block of foam and my CNC foam cutter.
Jul 14, 2013, 07:42 PM
God is my pilot
JimTMich's Avatar
This is going to be fun!
Jul 15, 2013, 07:18 AM
Wowplanes.com
Yes, fun is what it is all about. This is my first quad project, and I am going to need a lot of help as I go along especially when I get to the setup, programming, and flying steps. I will no doubt have many questions too.
Please feel free to jump in when you see me doing something obviously wrong. I want this to be a successful flyer.
Fahim
Jul 15, 2013, 07:36 AM
Wowplanes.com
The electronics compartment is part of the original cut and is very spacious and should give me lots of room to place the parts and battery in there. It also helps save weight by removing as much foam as possible without weakening the structure.
Next I prep'ed and fitted the hatch lid. The lid is made by slicing the top of the center plug about 1" thick. It is retained by rare earth magnets and has holes for cooling as well as a place for for the aliens to peek out. Also a rabbit ear antenna can be installed as in the comic books which will serve as a handle to lift the lid.
Fahim
Jul 15, 2013, 11:42 AM
Chad
TheOne420's Avatar
looks great
the only thing I hear about this style frame is that it takes a lot to get one to flip do to the wind resistance the solid frame creates. but for a straight flier I think it would be awesome.
how large are the thrust holes are they going to be motor and prop or large edf unit?
Jul 15, 2013, 01:22 PM
Wowplanes.com
Originally Posted by TheOne420
looks great
Great tip about the flipover. Hadn't thought about that and its a plus.
I am recycling 4 motors and props from my B24 that I have retired. See picture.
Fahim
Jul 15, 2013, 05:43 PM
Wowplanes.com
I continued with the hatch lid and also worked on the ducts.
Fahim
Jul 16, 2013, 07:05 AM
Wowplanes.com
The next step was to mount the motors.
The motors I am using have a Y mount, others have a + mount. I sandwiched and taped 4 pieces of 1/8" ply, drew the shape on the top piece extending the arms 1/2" past the duct perimeter, drilled the holes, and made one cut on a scroll saw. I ended up with 4 identical pieces for the price of one.
Fahim
Jul 16, 2013, 05:35 PM
as the name says!
AirplaneFreak100's Avatar
sweet can't wait to see the maiden
Jul 16, 2013, 05:36 PM
as the name says!
are you thinking of making this into a kit
i would buy it
Jul 16, 2013, 07:46 PM
Wowplanes.com
i would buy it
Your wish is my command. It will be a builder's kit.
Fahim
Jul 16, 2013, 07:47 PM
Wowplanes.com
I figured that prop wash hitting the flat surface of the motor mount plywood is not a good idea. It will create turbulence and down force fighting the up thrust of the props. So I dressed them up to be aerodynamic.
Fahim
Jul 17, 2013, 05:51 AM
Wowplanes.com
I have some kits to cut and ship today and a honey do project to help out with. So not much progress will happen. But I did manage to jazz up the hatch cover last night. Here are some pictures.
Fahim
Jul 17, 2013, 08:40 AM
Mortimer's Avatar
Very nicely done, but your ogival streamlining might have an effect on yaw.
A semicircular shape would have been more neutral.
Jul 17, 2013, 09:31 AM
Wowplanes.com
Good point. They are 1/2" wide and just over 1/2" high shaped like a wing's LE. I could sand them down to make a semi circle if that proves to be a problem. The props will be rotating in opposite directions on the 2 axis to cancel torque and thus yaw. The front and back rotate counterclockwise and the right & left go clockwise. If any additional yaw is introduced by the oval shape, it should be canceled out by opposite yaw introduced by the opposite rotating props, I think. Let's see.
"We are going where no man has gone before" says Capt Kirk.
Build Log UFO aka FLYING SAUCER awrightbrother Foamies (Scratchbuilt) 384 Jun 11, 2019 05:50 AM
Discussion Marvin Martian's Flying Saucer bobdaeronort Foamies (Scratchbuilt) 96 May 09, 2014 09:19 AM
Discussion UFO Flying Saucer Ron_RC Scratchbuilt Multirotor Drones 7 Feb 04, 2014 03:33 AM
Discussion Quad Saucer - UFO - RCG R&D - read this before making a saucer ! ggtronic Multirotor Drone Talk 54 Mar 21, 2013 08:53 PM
Discussion Alien flying saucer and X-UFO draxx Coaxial Helicopters 0 Mar 20, 2009 02:27 PM
