This thread is privately moderated by zanek, who may elect to delete unwanted replies.
Jul 13, 2013, 06:40 PM
Agressive driver
Build Log
Nutball Build- The airframe
Once the electronics were tested and the foam was cut into a circle I added the carbon fiber flats across the bottom of the wing and glued a 1" tall double strip of foam down the center of the underside of the plane. I made the motor mount out of a small block of wood and glued it onto the center of the plane.
Build Log KFm4 build on a 36" Nutball using 6mm Depron or FFF davereap Foamies (Scratchbuilt) 122 Feb 25, 2017 11:53 AM
Question What diameter NutBall to build with this motor? joker24458 Foamies (Scratchbuilt) 6 Apr 22, 2013 11:31 PM
Sold Nutball EPP Airframe fuzzyhead Aircraft - Electric - Airplanes (FS/W) 3 Feb 09, 2011 09:18 PM
Discussion The 8-Ball, (An 8 sided quick-build foamy for Nutball fans.) Cybernaught Foamies (Scratchbuilt) 104 Dec 05, 2010 08:54 AM
Discussion Building a Nutball and need a little help Sky_Captain Parkflyers 1 May 23, 2010 04:49 PM
