Jul 10, 2013, 07:43 AM
FREE VAPOR TRAILS
cwojcik's Avatar
Extreme Flight 60" Laser EXP
There is a lot of discussion floating around regarding this airplane so I figured I would start a thread as a repository for all that knowledge. Also, the plane should be released shortly, so this will become a build thread before long!
The Extreme Flight 60" Laser EXP is the fourth in Extreme Flight's line-up of 60" EXP airplanes, following the MXS, Extra, and Edge. Like all EXP's, significant liberties have been taken during the design phase that make the plane all it can be without sacrificing scale aesthetics. It can be flown fast, slow, from razor-sharp precision to wild 3D and everything in between. These airplanes are indestructible in the air and add a significant amount of performance and stability to the convenience and simplicity of the 48" airplanes.
Having flown the 60" Laser prototype, I can say that this is my favorite of the bunch. It has a lot of side area which means that precision and rolling maneuvers are easy and rock-solid. It has the speed and roll rate of the MXS, the solid forgiving nature of the Edge, and the precision of the Extra. This plane truly offers something for pilots of all skill levels and flying styles!
Like all of the 60" airplanes from Extreme Flight, the Laser is designed around the Torque 4016T-500 motor, 15x6-15x8 prop, Airboss 80 ESC, 4 mini servos, and 6S 3000-4000 mah batteries.
Video!!!
Extreme Flight 60" Laser EXP (5 min 21 sec)
Without further ado, let the build begin!
Components I will be using:
Torque 4016T/500 MKII
Airboss 80
Xoar 15x8
RJX FS-0391 servos
CC BEC Pro
Also, for this build I have decided to use Spot-On 1" and 1.25" servo arms.
OK, let's start with the wings. Pull them out of the wing bag and remove the plastic protector.
Start by tightening the covering and gently sealing down all the seams with a covering iron on low heat.
If you get a bit of pigment bleeding, you can wipe it up with acetone.
Now let's glue in the aileron horns. Remove all the horns and base plates from the hardware bag and set aside two of the longer ones (the one shorter one is for the elevator)
Insert into the aileron to test fit, then remove it and scuff with some sandpaper to promote adhesion.
Now, I like to line the outside with masking tape. This provides a nice border for where to cut away the covering.
Now mix up some 15-45 minute epoxy. Glue the horn in.
Now, you can pull up the tape, which if you applied it correctly, will have masked off the area around the horn base plate, greatly reducing mess.
Now let's mount the servos.
Unfortunately I have to slightly enlarge the mounts to fit the RJX servos...they are a bit longer than the recommended Hitec 7245's
Now reinforce the servo mounting area with a few drops of CA.
While the CA cures, we can prepare the hinges. This step is not strictly necessary but in my experience it greatly increases the life of the hinge.
Rub the centerline of the hinge with some wax. You can use a crayon, a candle, or a little chunk of ski wax, like I am doing.
Now place two pins through the hinge on the wax centerline.
Now insert the hinges into the surfaces.
Remove the pins. These were in there to keep the hinges centered in their slots. Flex the surfaces to the bevel to set the proper gap.
Place a drop of CA on the hinge and repeat on top. The wax that you put on the hinge will keep CA off the center, flexing portion of the hinge while still letting it wick into the portion that is in the wood. By not having CA on the center of the hinge, that portion will stay a bit more supple and last longer. This is not a necessity but I have broken a few hinges after a lot of really hard flying.
Now install the servo.
Drill the holes for the servo screws. I like using the Great Planes Dead Center tool.
Install the screws, then remove them.
Pull the servo out and place a drop of thin CA on the holes to harden them.
Now you can re-install the servo.
If you get some fogging from the CA on the hinges, you can remove it with acetone. Be careful not to get any acetone on the hinges themselves as this could soften the plastic or the CA bonding them in.
Now let's seal the ailerons. You can do this with blender tape, but I find that some matching covering makes for a much neater look when done. Cut some strips that are at least the length of the ailerons and 3/4" wide. Crease them in half down the center.
Use a bit of masking tape to hold the surface fully deflected.
Drop the gap sealing strip into the hinge bevel. Go over it slowly with a covering iron on low heat, sealing it down. If you are careful you will get a beautiful hinge line that is quiet, sealed, and invisible.
Now you can assemble the aileron pushrods. Unfortunately the Spot-On arms have a 3mm hole in them, so I needed to glue a larger Secraft ball link onto the pushrod with a little epoxy. If you do this, thread a 3mm bolt into the ball link and then remove it to form some threads in the ball link. This will keep it from pulling out. If done properly this results in a perfectly strong connection.
Build continues here
Jul 10, 2013, 08:07 AM
great job !!
Jul 10, 2013, 08:15 AM
Hardcore EP 3D Flyer
VR Eyedoc's Avatar
Subscribed
Jul 10, 2013, 09:40 AM
3D Sunset Flier
Buzzed's Avatar
Can't wait!
Jul 10, 2013, 09:56 AM
Stick banger
Ace4's Avatar
I really dig the blue & yellow scheme.
Jul 10, 2013, 10:22 AM
A man with too many toys
Like all of the 60" airplanes from Extreme Flight, the Edge is designed around the Torque 4016T-500 motor, 15x6-15x8 prop, Airboss 80 ESC, 4 mini servos, and 6S 3000-4000 mah batteries.
I have the 48 laser. Does the 60 feel much different in the air?
Jul 10, 2013, 11:17 AM
FREE VAPOR TRAILS
cwojcik's Avatar
It is more precise, stable, and not quite as quick/snappy. However, it has the same amazing roll rate, precision, and floatiness. It's a lot like the smaller one in its demeanor but a lot more airplane!
It's also one of the biggest feeling 60" planes out there. It has a lot of wing area and a tall fuselage which means that it presents like a 70" plane.
Jul 10, 2013, 12:57 PM
aka ECAA3D
m0dest's Avatar
I've been holding off on another 60" plane for this one.
Can't wait!!
Jul 10, 2013, 01:34 PM
wedoitall's Avatar
dang. i was wanting to get gasser next. i have the 60"
MXS, does it feel much bigger than the MXS?
Jul 10, 2013, 05:08 PM
This is BAT country!
Gonzo 1971's Avatar
Man, I was going to pick up a 48" laser. Think I will do a different 48" and then the 60" laser. This one should give me that big plane look and feel on a nice budget. Whats our time frame look like on these?
Jul 10, 2013, 06:53 PM
I'm Loving my 48" Laser, I can't wait for the 60". Only question; get the tradition red scheme to match my 48 or the cool blue, yellow, white scheme?
Jul 10, 2013, 07:19 PM
WADETN's Avatar
I will admit, being an extra guy I never was really that impressed by the looks of the lasers, until I saw these. Very nice looking airplane
Jul 10, 2013, 08:47 PM
Aeroplayin's Avatar
Yeah, I kiddingly gave Chris a hard time about the cowl not looking like the classic 200, but this looks very much like Matt Chapman's Laser Z230 that he flew in the early 1980's. This is a great looking Laser, and I'll need one.
Jul 10, 2013, 10:28 PM
Gonzo 1971's Avatar
A pic next to the extra and/or edge for size comparison will be cool. Getting ancy!
Jul 11, 2013, 10:23 AM
Team Extreme Flight
Doc Austin's Avatar
I think you probably have time to squeeze a 48" Extra in. Last week the Boss said the 60" Lasers go on the boat in a couple of weeks, so you'll have to build slow!
Sold Extreme flight Extra 300 exp 60" Gonzo 1971 Aircraft - Electric - Airplanes (FS/W) 3 Mar 08, 2013 04:19 PM
Sold Extreme Flight 60"Extra 300 EXP Gonzo 1971 Aircraft - Electric - Airplanes (FS/W) 4 Mar 04, 2013 10:16 PM
Help! Extreme Flight 60" Edge 540T EXP or 60" Extra 300 EXP Liberty10 3D Flying 12 Aug 10, 2012 10:36 PM
