New Product
Axe Frame
AEX Quadcopter
The AEX Quadcopter designed with a lot of thought, the frame is made by strong plywood which able to absorb vibration and you can buy it painted or ready for paint. The center of gravity (C.G) of the frame is located exactly on the center of the frame, where the flight controller and RX will be located. Each motor mount is located at the same distance from the C.G to increase stability and to reduce motors effort specifically on hover flight; this design makes the AXE frame ideal for any type of flight. ![]() Specs: Width: 310mm (motor shaft center to motor shaft center) Motor Mounting Hole Size: M3 pitch 19mm Weight: 180g for ready to paint frame to approximately 200g painted frame (frame only without any paint 151g) Recommended setups: Keda motor(KDA) : A20-50S/ A20-26M Tmotor : MT2206/MT2208 NTM: 2826A ESC: 12AMP/20AMP FOR NTM motor (flashed with SimonK) Battery: 3S 1800mah-2200mah 35C Prop size: 8x4.5 Max Two options for sale: Special price painted Axe frame for 45$ (Red/Black) Ready for paint Axe frame 45$ (White) PM for purchasing ![]() Test flight by Warthox:
Reason: update
Thank you Cam
Latest blog entry: Axe frame
Nice looking frame you got there, I will test one for you. I'm fond of plywood frames too. :wink:
Shaun h |
Shaun h |
Axe frame for night flight |
Practicing low pass with Axe frame quadcopter |
little preview
Thread Tools | |
Similar Threads | |||||
Sold | Heli-Max micro collection: 1SQ, Axe 100 CP, Axe 100 FP, Tx-R and RTF. | jl33fr33 | Aircraft - Electric - Helis (FS/W) | 9 | Jun 21, 2013 11:16 PM |
Discussion | axe 100 cp carbon frame | helipilot23 | Micro Helis | 4 | Mar 20, 2013 04:22 PM |
For Sale | Heli-Max Axe CX Nano RTF - Yellow Canopy | Aphro | Aircraft - Electric - Helis (FS/W) | 0 | Jan 10, 2013 04:24 AM |
Discussion | Which has a stronger frame Axe CP or Blade CP? | McReady | Micro Helis | 5 | Apr 22, 2009 09:59 PM |
