Help with designing a Cirrus Vision SF50?
This post is out of date, See post #28 after this post.
Hi everyone! I've noticed a lack of Vision SF50 designs(It's one of my favourite Airplanes) and as I want to make one in the near future(2-4 months time) I've decided to make a 1/13 scale EDF foamie design. ![]() First of all, so you know what the Airplane I'm talking about looks like: http://en.m.wikipedia.org/wiki/Cirrus_Vision_SF50 So I figured out that 1/13 scale equals: Wingspan: 90 cm Length: 72.4 cm Height: 24.6 cm And just for a joke: (Or ultra accuracy!! ![]() Cabin Width: 12 cm Cabin Height: 9.5 cm I'm aiming for a less than 1.5 Lb AUW weight with EPP body, Retracts, Ailerons, V-tail, and 51mm EDF unit. Ideally I want an AUW weight of 1 Lb, I can forget about Ailerons and use just dihedral and the V-tail if necessary to keep it light. Regarding parts, are there any better choices than these?? 51mm EDF: (no motor) https://www.hobbyking.com/hobbyking/s...inch_51mm.html Motors: (Can you help me pick one? I'm looking for a lowish kv for slow flyer) C10 Micro brushless outrunner: https://www.hobbyking.com/hobbyking/s...er_2900kv.html Turnigy 1811 2900kv: https://www.hobbyking.com/hobbyking/s...er_2900kv.html Turnigy 1811 3800kv: https://www.hobbyking.com/hobbyking/s...or_3800kv.html If there is a better motor and/or EDF(I'm sure there is! ![]() I'm aiming for the my SF50 to fly at a "slow scale looking speed" if possible. ![]() Thanks a lot! |
1lb is gonna be hard to achieve with retracts, unless your talking mechanical.
A 35" Wing span i don't think a 50mm edf is the way to go. your more in the range of a 64-70mm just to give you an idea edf shroud -50g motor -70g 20amp Esc-30g 3s lipo- 100g-150g 2x servos - 20g the basic and your already at 250-300g which is pretty close to 3/4lb and you dont even have an airframe yet. |
So you think a 64mm EDF will do for a 90 cm wingspan plane? Sounds right to me ![]() Thanks a lot for your help |
A most commendable goal, I wish you well. On my current build I'm hoping to stay under 11lb! Regarding the Cirrus Vision SF50, funny thing, I live just across the Hwy from the Cirrus plant, and I've only seen flying a few times. Good luck on your build, I'll be watching your progress. |
![]() As for only seen it flying a few times, well there is only 1 of them at the moment. ![]() But anyway! What is your impression of it? I think it's a lovely little Jet Airplane! Thanks, and good luck on your build! What's it modeled on? and how big? |
It's hard to say, I barly notice it. And your right to say it's a lovely little Jet, because it seems so. There usually on there landing approach, reasonably low and very quiet. The runway is to my north, across the Hwy, less than 3/4 mile away. The Minnesota Air Gaurd (148th) is also there, and I see a whole lot more F-16s everyday. Lots of C-130's out of the Twin Citys- practicing touch -and-goes. Occasionaly other stray warbids drop by, too! Thanks, and good luck on your build! What's it modeled on? and how big? It's after the Aviation Design E-Scorpion, most of what you ask is in firt post here: https://www.rcgroups.com/forums/show....php?t=1819176 |
Looks very cool!
So sorry to read that you had a Stroke. ![]() What is it about the E-Scorpion that makes it so heavy for size?? About the Vision SF50, nice to hear that it's quiet for it's size, I didn't know that!(But it's probably useless to try make mine have scale sounding noise, LOL! ![]() I wonder how to make the Fuselage? I want to make it look perfectly scale,(Hobby quality! ![]() At the time of writing I will only have EPP sheets 3-20mm thickness and Geldipac 3mm Sheets available to make the Airframe with. ![]() |
Reason: Forgot a word
I found this thread on bending Depron, do you think it will work on EPP???
https://www.rcgroups.com/forums/show....php?t=1079598 P.S Also, if Retracts are too heavy, would omitting them and belly-landing the plane instead hurt it? |
Reason: P.S
Built a few of GGRN designs,
Depends on what best suits you. Some carve, some use bulkheads and skins Many of us belly land, some use epoxy and glass, some use tape, some use silkspan and wbpu or glass and wbpu to toughen them up, but this also adds weight. You'll first need to start with good 3 view drawings and stations would be a bonus. |
![]() I found this EDF at Hobby king, people say the specs are wrong and that it's more powerful than the specs say it is: https://www.hobbyking.com/hobbyking/s...Assembled.html Looks like an ok EDF, but I'm very open to suggestions! |
Found a three view Picture, looks like it will do after a bit of photoshop treatment!
http://www.cirrusaircraft.com/static...n/geometry.jpg ![]() ![]() P.S Looking from the pic it looks like the SF50 has positive dihedral, YAY! ![]() |
Found a few things for you.
Videos http://www.cirrusworld.com/tags/vision/ There is another view similar to this one, but I haven't found a large enough one.. This one took a couple of hrs off and on. Looks like you beat me to it!! http://www.bing.com/images/search?q=...ages&FORM=IGRE |
Well, at least two people knew about the pic before it was posted here! (you and me!
![]() So if I use Adobe Photoshop to add some rulers on the pic, It should work! ![]() Thanks for the videos, I didn't see them! |
What I did on the Scorpion, was to take the separate views--side only, top only, etc, . I made several copies in a file, so I could disect them into top and side view. Once you crop a photo and save it ,the original is toast!! Printed them out, made them into PDF files, and enlarge them in Adobe Reader. That gave me the scale that I wanted. A little trial and error involved---Have lots of ink for your printer!!
![]() I think first I may have figured out the scale. Metric is not my stong suit, but used it anyway. In my case I converted , lets say total fuse length from mm to inches. Used this one: http://www.towerhobbies.com/help/convcalcs.html As you probaly already use metric, print out the photo you have, measure total fuse length, take that number and divide it into what you think you want for length on your model. I measured the in the photo, and on my screen got 132mm =5.1968" Lets say you wanted a fuse length of 35", divide that by 5.1968=6.7349--That's the multipling factor any length measured will be X that number. Do the same for width, it may not be the same number. Or just go by reducing the scale. Real one is 29.6ft/9.02m Same 35" model scale would 10.114 to 1 I used the first method, as I wanted a certain size and wasn't worried about what scale it was---There is no real Scorpion! Who will know! ![]()
Here's one, I missed that air show, just watched the Blue Angles from my back yard. In fact the Friday before the show, they flew directly over my house at about 500ft. All of them! Hell-of-a way to get woken up in the AM. This is the matching photo to the one we both found. It is so small!! If where you got the first one, maybe they have this, just BIGGER! |
Thread Tools | |
Similar Threads | |||||
Discussion | Help with Wing flap Design | thandlovsky | Ornithopters | 3 | Jun 12, 2013 04:33 AM |
Discussion | Design Build a RC plane - Engineering Design Competition - Need Help | Briickhouse | Electric Plane Talk | 21 | May 29, 2013 12:08 PM |
Discussion | Help needed with production prototypes for new 3d non-profile design | BillyWhiz | Foamies (Scratchbuilt) | 1 | Apr 04, 2013 02:22 PM |
New Product | Pence Aviation Announces Cirrus Vision Jet Kit Development | penceaviation | Electric Ducted Fan Jet Talk | 123 | Sep 04, 2011 09:49 PM |
Wanted | Help with Vision Radio with Futaba RX-Ham Band | orbitone | Aircraft - General - Radio Equipment (FS/W) | 5 | May 10, 2007 09:19 AM |
