Jul 04, 2013, 05:21 AM
DJI Released New Firmware 3.14 for Naza-M V1、V2 And Phantom!
What’s New for Firmware?
*Optimize the compatibility for Zenmuse H3-2D gimbal.
*Add calibration function of X1 channel(X1 is used for pitch control of normal gimbal and Zenmuse H3-2D gimbal).
*Change the default aircraft type to X4 instead of I4.
What’s New for Assistant Software?
*Add calibration function of X1 channel(X1 is used for pitch control of normal gimbal and Zenmuse H3-2D).
Jul 04, 2013, 05:59 AM
g0t rabb1t?
ABLomas's Avatar
.... and flyaway function kept active and working well, right? ;-)
Jul 04, 2013, 07:01 AM
Hmm, nothing for the Lite? Are they going to get totally different upgrades/fixes (if any) ?
Jul 04, 2013, 08:09 AM
Begin with end in mind...
power's Avatar
Jul 04, 2013, 08:10 AM
power's Avatar
Awesome....I do hope they patched up the random fly away thing
Jul 04, 2013, 10:02 AM
DJI never acknowledged the random flyaway in v3.12. If they fixed it, it would most likely be quietly added to an update. Like this one.
Jul 05, 2013, 12:55 AM
Nope.Never.
Jul 05, 2013, 06:15 PM
maybe they have finally made a configurable switch for it
Jul 07, 2013, 12:57 PM
kryptoknight's Avatar
I updated my V1 hardware to 3.14 firmaware and did all the callibartions, but when I push the sticks to arm the motors, it wont arm at all. I re callibrated my TX 3 times already and set the endpoints to 100%. Any ideas what's wrong? I never had issues with firm ware 2.02.
Jul 08, 2013, 06:33 PM
Dennis H.'s Avatar
Im in the same boat too, Cant get the motors to run now
Jul 08, 2013, 07:12 PM
Restore to factory defaults and program again
Jul 08, 2013, 07:19 PM
Dennis H.'s Avatar
Yes done that, still nothing, i even uninstall and reinstall the software, and still cant get the motors to come on.
Jul 08, 2013, 07:24 PM
power's Avatar
Are you running SimonK firmware on your ESC's? If so, jack your motor idle speed to "high" in the assistant.
Probably not the issue but some motors/esc combos will not fire at the "recommended" setting. I have one copter that does and one needs to be set to high. Since yours had been working it may not be the problem. Just something to try..
Jul 08, 2013, 07:28 PM
Dennis H.'s Avatar
I have the Naza V2 with GPS
Jul 08, 2013, 07:38 PM
power's Avatar
You can still try...
Discussion New Firmware of DJI IOSD Supports Naza-M/Naza-M V2 Now! DJI INNOVATIONS Aerial Photography 3 Feb 08, 2014 12:10 PM
Discussion DJI has released the new firmware v3.12 for Naza-M DJI INNOVATIONS Multirotor Drone Electronics 24 Aug 19, 2013 07:47 AM
Discussion Naza V2 versus Naza M (v1) with updated firmware Jelico Multirotor Drone Talk 3 Jun 05, 2013 04:43 AM
Mini-HowTo Turnigy 9x v2 standard firmware, mode switch 3 position switch for dji naza gps :) stein3247 Multirotor Drone Electronics 3 Jul 20, 2012 04:23 AM
