This thread is privately moderated by shigetyann, who may elect to delete unwanted replies.
Jul 01, 2013, 11:08 AM
shigetyann's Avatar
Art-teck AT-6 Texan flight test
I flew AT-6 on last Sunday, on 30th June.
This was a test flight with engine sound.
Short footage though, you'll see how fantastic this plane is
Enjoy!
Shige
Art-tech AT-6 TEXAN flight test (2 min 6 sec)
Latest blog entry: My Macchi-M67 oing on!
Jul 01, 2013, 11:21 AM
Grumpa Tom
Kmot's Avatar
Wow! The sound module on this model is very loud! Was the audio from the camcorder boosted?
Jul 01, 2013, 11:25 AM
Sell...er's Avatar
Man ,,,That sounds Cool,is it expensive??
Steve
Jul 01, 2013, 11:42 AM
shigetyann's Avatar
Hi Kmot
I did the sound a little bit louder in editing.
The engine sound was let out from this plane.
In low pass clip, the sound was heard the same in actual.
Shige
Jul 01, 2013, 11:51 AM
shigetyann's Avatar
Steve
Hi Steve
The sound system is around 30 bucks at Hobby King.
>Hardware & accessories. > Audio Systems & Parts
"HobbyKing Plug N Play Aircraft Engine Sound Module System"
Below interpretation is from the explanatory booklet.
This brilliant and easy to fit engine sound module system allows you to bring your small electric model to life with a realistic aero engine noise that is proportional to your throttle! The sound produced adds realism without being excessively loud making it perfect for any flying field.
It takes a mere matter of minutes to hook this system up, the proportional & realistic aero engine sound, which includes engine start up/shut down sequences is pre-programmed and calibrated to work directly off your throttle/ESC via the supplied lead, power for the system comes directly from the supplied XT-60 splitter lead and the speaker lead is also included. If you are looking to add even more realism to your EP scale or warbird model, look no further!
Includes:
Module
Speaker
Y-Lead
Speaker Lead
XT 60 Converter/Power Lead
ESC to Module Converter Lead
Specs Module:
Working Voltage: 10v~17v
Weight: 42g
Dimensions: 74mm x 22mm x 34mm
Specs Speaker:
Rated Power: 15w
Frequency Response: 200~8000hz
Rated Impedance: 8 ohm
Harmonic Distortion: 3%~5% TMD
Sensitivity: 86~87db/W
Weight: 118g
Volume (max): 60db
製品 ID: 9041000153
Unfortunatelly, now in backorder
Shige
For Sale Top Flite Gold Edition AT-6 Texan PROPJET Aircraft - Fuel - Airplanes (FS/W) 1 Jan 11, 2013 08:41 PM
For Sale AT-6 Texan 66 in ws rtf w/ Saito 100 4 stroke nice radman615 Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2013 12:44 AM
Discussion 6 Ch Art-tech 2.4ghz Large At-6 Texan aclinml Electric Warbirds 5 May 26, 2012 06:55 PM
