Mopar92,
I use pneumatic tool lub oil as an after run oil. It is best because it absorbs water that is in the glow fuels thus preventing rust. Dick Huang |
I heard that some pilots use WD-40 to use either for winter storage or after flight....Is this bad???
I am new to rc. What is after run oil and how do you use it.
After run oil is to be run through the engine after a days flying is done. Prevents corrosion and rust to bearings and surfaces inside the motor. Alcohol used to make glow fuel can and will draw some moisture. You know what moisture can do. In our race cars that run alky, we run gas through everything to prevent this. Of course that is not a good idea here.
Hey guys, maybe you can answer this....
I am using Morgans Cool Power 10%....I was reading on the jug that they do not recommend the use of after run oil due to their fuel already contatining rust preventative. Whats y'alls thoughts? A little extra oil won't hurt anything in IMHO. |
Corrosion X By Far is the best after run oil!!
JW |
Mopar,
Corrision X also has a differnt name of ACF 50. Same MIL spec but just a different name. Iam am an aircraft mechanic and i get it at work. But Iam sure that www.aircraftspruce.com, or Marine type stores should have it under the ACF-50 name. It comes in a large Aerosol can, the can goes along WAY!!!! I have been using it for a long time, but i have recently seen it reviews in RCM about using for electrical use also!! It is much better for engines due to its ability to creep into spots that Marvel tool oil or Transmission fluild can get to. If you have trouble finding it, juat email me and i will see what i can do. Planefixr1@aol.com |
Corrosion X
I've used the stuff for years and its excellent. I use it an all kinds of things..anywhere you need to protect something or to lube it. Its used for marine applications so you should be able to get it at any well stocked boat dealer...if you can't do that heres the web site:
http://www.corrosionx.com/ you can order it online there...really great stuff |
What hasn't been mentioned so far is how to shut down the engine after the last flight of the day. Because the methanol absorbs water out of the air your first step before using any after run oil is to get rid of as much of that methanol as possible from inside the engine. The best way to do this is to run at full throttle and either pinch or remove the fuel line until the engine stops. If you pinch the line then keep it pinched for a few seconds after the engine has stopped or the residual muffler pressure in the tank will only force more fuel back into the carb.
Proof that this system works comes from CL flyers whose engines HAVE to shut down like this after every flight (crashes excepted ) and rusted bearings are virtually unheard of. However, they also tend to use a lot of castor in their fuels which is an excellent rust preventative in itself. As for the latest Morgan fuel warning, unless they've decided to use some strange rust preventative that they KNOW reacts badly with others then it shouldn't be a problem. Then again, they don't even know how to make an FAI fuel (check their specs). |
Thread Tools | |
Similar Threads | |||||
Help! | After run oil options for Saito fg14 gasser | BHChieftain | Engines | 49 | Sep 18, 2016 06:30 PM |
Discussion | After-run oil? | Twangmaster | Engines | 30 | Jun 01, 2016 05:56 PM |
After Run Oil | rabosr | Fuel Plane Talk | 28 | Jun 12, 2015 03:44 AM |
