Sep 09, 2019, 08:46 PM
Build straight - Fly twisty
Whiskers's Avatar
Very nice indeed.
The last landing is one for the highlight reel
Sep 09, 2019, 08:58 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Nice bit of flying there Bob, lovey place to fly off water, pond/lake is just a nice size and the surroundings are really nice, maybe we can go there for a fly when I came over
Lockey
Sep 19, 2019, 11:26 PM
Lockey's Avatar
I got to thinking after seeing your Vixen fly Bob and thought it was looking a bit dated .. so I have decided to do a bit of a face lift and will now be able to take a 8" prop and lower kv motor for quieter running
Hope you like it ..
Lockey
Yesterday, 06:26 AM
Lockey's Avatar
I wanted a sea plane to fit in my suitcase, .. small .. light .. one that I know (or felt) would fly ... and able to be put together really quick at the other end .. not too worried about bringing it back ( I will leave it with my friend) so it can be glued together when I get there but almost ready built ..
Here is my mini suitcase Vixen 620 (620mm being the wing span) just minimum glue holding it together to test fly, I will break it apart into 3 sections
Took me less than a day to cut it out and put it together .. used mainly CA glue and hot glue to hold the 3 sections together so I can pull them apart reasonably easily
Floater-Jet Replacement Motor AXN 2208 2150k
5 x 5 Prop
Plush 18A ESC
3 x 9g servos
Weight (without battery) 270 grams
Weight with 1000/3s batter 370 grams
Lockey
Yesterday, 09:33 AM
Lockey's Avatar
Maiden video
Lockey
Mini Vixen 620 Maiden (6 min 34 sec)
Yesterday, 01:11 PM
skumgummi dave
Lockey:
Your video is marked private. We can't access it.
Dave-
Yesterday, 02:37 PM
Retired CAD guy
birdofplay's Avatar
I'm thinking that it might not be fully up-loaded yet
Else,
Youtube has some settings specific to your upload that need to be changed
Under "VISIBILITY" on the right side of the screen
Yesterday, 03:32 PM
Retired CAD guy
birdofplay's Avatar
Tony has sent tentative files for both a 750 and 850 span version of his Traveling Vixen.
I have them prepped and ready for a test cutting.
More as the plot thickens ;^}
Bob @ Hoosier Cutout service
Yesterday, 08:35 PM
Lockey's Avatar
Sorry about the "private" video guys .. not sure what happened, never done that to me before .. although You-Tube have been messing A LOT with their settings .. if its not broke why fix it
I am away for a couple of weeks so Bob is going to build my new 850 design of the revamped Vixen .. thats right isnt it Bob ? watch this space for LOTS of build pics and a maiden video from Bob
Lockey
Yesterday, 09:59 PM
Retired CAD guy
birdofplay's Avatar
I'm ready to cut those 1st prototype parts!
It's pretty boring in Adelaide , you might forget to come back home !
But don't miss the boat as it's a long hard drive across the Nullarbor Plain !
I spyed that "Longest Straight Road" from the air on the way back from Perth !
I thought that I80 across Utah was bad, but, WHEEW , thats a stretch of road !
Today, 09:06 AM
Lockey's Avatar
It sure is a Looooooooonnnnng straight road Bob
I think the 850mm wing span should be a really smart flier with maybe a 1000 - 1350 kv motor and a 8/9" prop .. should fly really slow .. and fast too
Once cut out should only take one and half to two days to build, this type of model is a very quick build and I have simplified the position of the 3 servos for ailerons, elevator and rudder .. I expect it to come in at about 700-800 grams including battery
I am thinking
Turnigy Aerodrive SK3 - 3530-1340kv motor or similar
8 or 9 x 4.5 prop
Plush 40A ESC
3 x 9 gram servos
5 mm CF tubes in wing, horizontal stab and 3 or 4 mm CF in booms
Oh yes .. and I think new thread and new name .. this one named by Bob .. "Viking"
Lockey
EDIT .. Here you go Bob .. new thread started ... https://www.rcgroups.com/forums/show...0#post42790285
Today, 09:20 AM
Retired CAD guy
birdofplay's Avatar
Good thoughts.
No problem with equipment either.
Viking was just a preliminary suggestion , but, ... Hey if you like it I'm good too ;>}
Today, 09:26 AM
Lockey's Avatar
This is the second flight of the mini Vixen 620 ..
I just added a bit of trim tape to make it easier orientation, flies quite nice, just have to remember to keep the speed up a bit on the turns and landing
Yes Bob, I like the name "Viking" for the big one
Lockey
Mini Vixen flies again (7 min 13 sec)
Today, 12:23 PM
Retired CAD guy
birdofplay's Avatar
I like that everyone there seems to view the Goal as a Target !
OH OK you moved out there to be part of the target.
Is there a Height limitation at this Field ?
Looks like everyone has terrific Ground range ;^}
Today, 01:01 PM
Retired CAD guy
birdofplay's Avatar
Viking thread started here
https://www.rcgroups.com/forums/show...NG-850-mm-span
Build Log Dedicated GOPRO delta airplane take off from grass+water+snow+hand launch: POLARIS XL ggtronic FPV Talk 133 Apr 30, 2017 04:47 PM
Question Recommendations for flying off grass and snow, maybe even water. Iflyjets Foamies (Kits) 10 Feb 27, 2013 06:34 PM
Question Water Slide or Vinyl Decals Fast Freddy Scale Kit/Scratch Built 6 Jul 03, 2004 07:02 AM
Another water slide decal question Red Baron 47 Electric Plane Talk 0 Oct 31, 2001 10:50 PM
Decalcote for water slide decals, where to buy? Red Baron 47 Electric Plane Talk 9 Oct 31, 2001 09:49 AM
