Jul 01, 2013, 05:52 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Kadil, Flying weight with a 1500 / 3 battery was 587 grams (22.7 oz) I think the Polaris comes in around that weight and its almost incidental wing size and shape
Maybe the turned down wing tips, or maybe the twin booms (or both) ... my Polar -Cat flies very similar and it has the twin booms
I am going to have to build another one real soon so I can do some more testing
By the way, if anyone is wondering what the difference is between the round top and square top (see pics below) square top would be just a little easier for the guys who are not too good at bending Depron, you could also cut off the tips of the wings and make some tip floats like the Polaris
When bending Depro, the only thing you must do (if you are bending it cold as I do) is to put some packaging tape on the outside otherwise you will just crack the Depron, the tape can be removed when the bending has been done
Lockey
Jul 01, 2013, 06:15 PM
Row 0, Seat A
G550Ted's Avatar
Originally Posted by Depronicus
Yes, it really is. I suspect Lockey is one of those people who doesn't require a lot of sleep.
Umm.. I think more like a person who has many years of experience as a craftsman and small business owner who knows how to GIT-ER-DONE!
Ted
Jul 01, 2013, 09:34 PM
Lockey's Avatar
I am not an early riser, but do have more time now I am semi retired
I am also a fairly quick builder
Lockey
Jul 02, 2013, 12:58 AM
Lockey's Avatar
This is the way I put my plans together when I can’t be bothered to drive down to my local Office Works to get them printed
As I have JUST finished doing the plans for my new Vixen, I thought I would post how I do it (Lenny was talking about this on another thread)
The first pic is my printer screen, choose “poster” and you should be able to change the overlap etc, I usually leave it a zero.
I have found it easier to use a "glue stick" instead of tape to fit the pages together ... much easier, I glue all the top row, 2nd row and so on and then glue the rows together .... AND I always put a measurement grid / scale on all my plans to check to see if your plans are somewhere near the size they should be … I normally find mine is ever so slightly smaller than the measurement scale
Lockey
Jul 02, 2013, 08:02 AM
Retired CAD guy
birdofplay's Avatar
OK, for all those wanting to build this plane,
but, not willing to print , tape, cutout ,paste and then Cut the foam.
I have the Vixen on my Products page ready for your order. :-)
http://www.hoosiercutoutservice.com/cutouts/Listing.htm
I just do a CNC foam cut out service, not full kits.
However, I do include Ply horns.
Been doing this since 2007 in my retirement as a side line.
Bob
Hoosier cutout Service
Jul 02, 2013, 09:36 AM
Lockey's Avatar
Bob does a very nice job of cutting the parts, I wish I was nearer so he could cut out all my parts … only thing is … he is too darn cheap
I spent more than a couple of hours today pasting up the plans and cutting out the parts, the edges aren’t square so I have to now sand ALL the parts before I can start to put them together … wish I could get the parts cut … MUST GET ME A CNC CUTTER
Good on yea Bob, keep up the good work my friend
Lockey
Jul 02, 2013, 12:47 PM
Retired CAD guy
birdofplay's Avatar
SO WHADAYA THINK ...
Should I raise em 10, 20 30 % :-}}}
NOT !
regardless Thanx for Comps !
Bob
Jul 03, 2013, 04:48 AM
Lockey's Avatar
Started the new (replacement) build, I think I will do this one without the twin booms to see how it flies
Lockey
Jul 03, 2013, 05:59 AM
It was great to meet you and have a chat the other night, I will have to try and find the
time to build a Vixen it's a great design.
Cheers Kev.
Jul 03, 2013, 06:07 AM
Lockey's Avatar
Cheers Kev.
Hi Kev, good to see you here mate and yes it was great to meet up and have a chat
Pity I couldn't show you the finished product when you called in ... as its STILL UP A TREE
Oh well, new build under way and can test it without the twin booms before I fit them
Lockey
Jul 03, 2013, 11:15 AM
Going to follow this one... Looks great.
Jul 03, 2013, 06:18 PM
This design does look great! I love the Polaris as well, but thought that a pusher config simply to bring the motor closer to the esc/battery would cut down on weight (no long lead wires) and simplify construction. I'm going to start construction on a single boom version asap (within a day or 2). I'll change the motor mount a bit, I don't have and don't prefer stick mounts.
Great design and great idea though, thanks for the plans, I'll post notes when it's underway. Do you have any experience with this as a vee hull for improved water handling?
Jul 03, 2013, 07:27 PM
Lockey's Avatar
I am just drawing up a motor mount for anyone who can't get or doesn't want to use a stick mount
Polaris doesn't seem to have much trouble on the water, but it wouldn't be difficult to add a "V" hull if wanted
Look forward to seeing your build Carl
Lockey
Jul 03, 2013, 10:35 PM
Lockey's Avatar
For anyone who doesn't want to use a stick mount, here is a ply mount
Parts on PDF ... Alternative motor mount parts
Lockey
Jul 03, 2013, 10:37 PM
Lockey's Avatar
For anyone who doesn’t want to use a stick mount, here is a ply mount
Parts on PDF on A4 .. Alternative motor mount parts
Lockey
Build Log Dedicated GOPRO delta airplane take off from grass+water+snow+hand launch: POLARIS XL ggtronic FPV Talk 133 Apr 30, 2017 04:47 PM
Question Recommendations for flying off grass and snow, maybe even water. Iflyjets Foamies (Kits) 10 Feb 27, 2013 06:34 PM
Question Water Slide or Vinyl Decals Fast Freddy Scale Kit/Scratch Built 6 Jul 03, 2004 07:02 AM
Another water slide decal question Red Baron 47 Electric Plane Talk 0 Oct 31, 2001 10:50 PM
Decalcote for water slide decals, where to buy? Red Baron 47 Electric Plane Talk 9 Oct 31, 2001 09:49 AM
