Jun 30, 2013, 08:43 PM
Illegitimi non carborundum
grosbeak's Avatar
DA-50R - no spark
I have an aerobatic airplane powered by a DA-50R. A couple of weeks ago I misjudged a landing and came down just short of the threshold in the tall grass and standing water; the plane threw up a big sheet of water as it touched down, then flipped onto its back.
Immediately afterwards I was unable to start the engine. I put that down to a wet spark plug boot. However, I am still unable to start the engine. I've eliminated the receiver, ignition kill and switch from the equation by connecting the ignition battery (A123 6.6V 2200 mAh) directly to the 5.2V voltage regulator. With the plug out and in the cap I'm not getting any spark.
I would appreciate some advice on how to proceed.... thanks.
Jul 01, 2013, 02:15 PM
grosbeak's Avatar
Problem solved.
Jul 01, 2013, 02:22 PM
pilotpete2's Avatar
Oh c'mon now!!! What was it????
Inquiring minds want to know
Pete
Jul 01, 2013, 05:34 PM
grosbeak's Avatar
Oh, great - NOW someone chimes in! :P
I went down to my workshop to try a few tests. Now, according to Albert Einstein, the definition of insanity is doing the same thing over and over again and expecting different results. I, however smart, am no Einstein, so I started by repeating the spark test I did at the field yesterday. In my defense it is darker in the shop with the lights off, so it wasn't like I was doing the EXACT same thing over and over again.
It sparked! It sparked with the plug against the block, it sparked with the plug not against the block, and it sparked when I reconnected the physical switch and the ignition kill. And when I took it outside, trying not to raise my hopes too high, it started!
I'm happy and have visions of dollar bills floating back into my wallet, but I'm also a little confused. Of course, this isn't the first time I've used the ol' take-it-apart and put-it-back-together approach to something that wouldn't go, and it's not the first time that approach has worked. But I welcome your theories as to why it works now and didn't work yesterday.
Jul 01, 2013, 05:52 PM
pilotpete2's Avatar
My bet is that there was moisture in the plug cap, and it finally evaporated
Cheers,
Pete
Sold DA 50R with standoffs pitts muffler/with exhaust bendix1 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 17, 2013 05:40 PM
For Sale DA-50R fresh from DA BjornBaal Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 04, 2011 08:24 PM
Sold Desert Aircraft DA-50R $385 shipped (No Muffler) xwingnut Aircraft - Fuel - Engines and Accessories (FS/W) 1 Sep 19, 2010 08:59 AM
Sold DA-50r w/muffler AL FORD101 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Dec 28, 2006 01:51 PM
Wanted DA-50r moter Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 02, 2006 06:04 PM
