Feb 05, 2014, 04:19 PM
One Idiot is plenty...
Dbox's Avatar
Originally Posted by Gavin Trussell
It needs to have weight as it is so long . Look at the length. Weighs on a bearing cg machine at exactly 62 mm from leading edge. With or without ballast. As do the other 3 bars. Its ok if you dont think its right , dont use it.
Gavin
No Gavin.
Your ballast is very nice engineered ,
I just did not get how it works to keep CG in right position.
My bad.
Yuri
Feb 05, 2014, 04:20 PM
Team Horizon Pilot :)
No biggie. Its just long to compensate for noseweight
Feb 05, 2014, 04:39 PM
Retirement is good
Novel idea Gavin but have you noticed a difference in pitch or yaw response due to the increased inertia caused by the very long weight?
Feb 05, 2014, 05:03 PM
No i have run this ballast in my blasters and snipes last year. Havent noticed or felt effects.
Feb 05, 2014, 08:03 PM
Retirement is good
Interesting. Thanks...
Feb 05, 2014, 09:46 PM
Oleg Golovidov
olgol's Avatar
build pics
Assembling a Snipe for a customer...
Feb 05, 2014, 10:02 PM
M Seid
M Seid's Avatar
Oleg, your work is worth twice the what you are charging. Just an amazing amount of attention to detail.
Feb 06, 2014, 04:52 AM
AERO+
nickbox's Avatar
Amazing build Oleg!
I am building my white too.
Feb 06, 2014, 05:02 AM
hello,
is still FAI legal? the T blade seems to increase the wing span, does it still fall into the 1,50m?
thanks,
Cedric,
Feb 06, 2014, 06:11 AM
I don't want to "Switch Now"
pmackenzie's Avatar
The Snipe span without the peg is comfortably under the FAI limit, so that installation should be fine.
Feb 06, 2014, 09:04 AM
usaf3kteam
rcgeorge's Avatar
Nice Oleg
Feb 06, 2014, 09:43 AM
mikeff's Avatar
Originally Posted by ced_toulouse
hello,
thanks,
Cedric,
I wondered about that so I measured the span and slid the peg out to meet the 1500mm span limit - see picture 1.
My build details here.
I ended up with it much further in when it was fixed - see second picture. You will need to check the exact situation on your own wing with a measuring tape.
Feb 06, 2014, 12:47 PM
Dbox's Avatar
Bravo Oleg !
Yuri
Feb 06, 2014, 01:15 PM
Oleg Golovidov
olgol's Avatar
Thank y'all for your kind comments. I did not think I did anything special or very different from other builders. But you all can certainly continue praising me, I really enjoy it Mike Seid called me a narcissist a few times, but I am not sure I am the only one he called that (hey Mike, thanks).
Feb 06, 2014, 01:25 PM
AERO+
nickbox's Avatar
Oleg, I noticed you bent the pushrods like Joe did, what's the advantage bend it like that?
Build Log Blaster 3 DLG from Kennedy Composits simages Hand Launch 7 Dec 03, 2015 06:03 PM
Sold ELF X tail from Kennedy Composites mgroves Aircraft - Sailplanes (FS/W) 1 Feb 10, 2013 02:26 PM
Discussion Take a break from the sniping ... and enjoy a greate father son moment ... logan5 Life, The Universe, and Politics 3 Oct 04, 2012 10:09 PM
Wanted Snipe Composite, Wingeron davonat Aircraft - Sailplanes (FS/W) 2 Mar 30, 2008 09:15 PM
Discussion Snipe Composite davonat Sailplane Talk 5 Mar 30, 2008 04:30 PM
