Jun 28, 2013, 02:58 PM
You sabotaged my plane.
eliworm's Avatar
Build Log
EQT - Design inspired by Lee Renaud
The EQT was inspired by the .049 powered Q-tee designed by Lee Renaud years ago. The Q-tee was my first RC model back about 1980, so I have always had a soft spot for Parasol type designs. Over the years I have built a number of them. The last few years I had converted a few to electric. I always thought it would be nice to come out with a similar design but have it ready for electric power right from the start rather than a conversion. The EQT is the result. Originally I designed this version for myself and my kids. (I have three more pilots in the family). I have had many people inquire about a kit for my version so I decided to release a short kit. If your looking for an original Q-tee this is not your plane. My version is lighter as well as accommodations for an outrunner and other minor changes.
All the hard parts to cut out are done on the laser. Here is a list of the items you will need to complete the basic airframe. Regular builders my have what you need in the scrap box.
For fuselage.
1 each 3/32 x 1/8 x 36 balsa
1 each 1/8 x 1/8 x 36 balsa
1/8 x 1/4 hardwood for cabanes
For wing
1 each ¼ x ¼ x 36 balsa
1 each 1/8 x ½ x 36 hard balsa or hardwood
1 each ¼ x 1 balsa trailing edge stock
For tail
1 each 3/32 x 3/16 x 36 balsa
1 each 3/16 x ¼ x 36 balsa
1 sheet 1/16 x 4 x 36 for wing and fuselage sheeting.
Landing gear wire .078 was used.
I have thought about releasing a full kit but at this time I'll stick with a short kit. I may in the future add more to the kit such as sheeting and wire, but I don't think it will be any time soon.
If your interested visit Hanger Cat our online store.
Photos coming soon.
Jim
Jun 28, 2013, 03:25 PM
eliworm's Avatar
Keep everything square. Remember neatness counts. On the sheeting for the forward fuselage, I have used both 1/16 and 3/32. What ever you have laying around will work. I have wet formed it in a single piece or as I did here, I planked the forward section and sanded everything smooth.
Jun 28, 2013, 03:29 PM
eliworm's Avatar
Here is the stab ready for sanding. Notice the strip wood is slightly wider than what's called out for on the plan. Use whatever you have that's close as long as it's the right thickness. I had 3/16 square on hand so that's what I used.
Jun 29, 2013, 10:48 AM
AndyKunz's Avatar
What size are you building this?
Andy
Jun 29, 2013, 11:44 AM
eliworm's Avatar
Hi Andy,
Spars are 36 inches but with the wing tips wingspan is 37.3 inches. I'll be adding more photos and details as I go.
Jim
Jun 29, 2013, 12:07 PM
Übung macht den Meister..
Deuce's Avatar
The Q-Tee was my first RC as well, about the same time! After a number of successful flights, I decided to do something stupid. Fear not, as I still have that Q-Tee, and (after more than 30 years!) I am almost complete with the repairs!
I also have an Aerosphere kit that I plan to convert to e-power. Some time ago, prior to purchasing the Aerosphere kit, I'd played with my CAD to attempt what you have accomplished.
Watching!
James
Jun 29, 2013, 01:42 PM
AndyKunz's Avatar
Originally Posted by eliworm
Hi Andy,
Thanks, Jim. It would be cool to have your design changes pointed out as you build. Basically telling us what you are doing differently than the original. It's always interesting to hear what others think.
Andy
Jun 30, 2013, 12:23 AM
eliworm's Avatar
Andy
The main change is the redesigned nose to easily mount an outrunner. Lighter ply at the nose. Simplified the fuselage formers. Swiss cheese the airframe for lighter weight. Wingtips for a bit more style. I also use balsa for the leading edge and spar in the wing but hardwood could be used if someone wanted to go that route.
This evening I was in a covering mood so I started there even though I haven't built the wing yet.
Jun 30, 2013, 02:59 PM
Visitor from Reality
Good project Jim. The QT was one of the first designs I recall from when I got access to US model mags, always have thought it a cute little model. Following your build, looking forward to how you fit/swap the battery.
Parasol mono's are neat and not seen enough!
D
Jul 02, 2013, 03:29 PM
SB-28 UK Display Pilot
GeeW's Avatar
A really nice little flyer you'll have there once it's finished.
Given it's four days since you posted, the wing must surely be finished and covered by now, right?
Gordon
Jul 02, 2013, 08:01 PM
eliworm's Avatar
Thanks for the kind words all.
Gordon, actually I have a few wings done but they are the wrong color. I needed some good build photos to post so I'll build a fresh wing. It's that four letter word in the way right now. (work)
Jim
Jul 05, 2013, 12:26 PM
eliworm's Avatar
OK, that four letter word that starts with a "w" is out of the way. (wife?)
Here is a photo of the elevators joined together with the 1/8 hardwood dowel. Ready for sanding and covering.
Jul 06, 2013, 08:04 PM
eliworm's Avatar
A few photos showing the wing center section. I do the shaping of the leading edge and trailing edge cut out before I join the two halves together. A strip of fiberglass wrapped around the center section and some final sanding and I'll be ready to cover.
Discussion 1/2A Q-Tee Lee Renaud design 1976 mikmerl 1/2A Planes 476 Sep 05, 2018 08:59 AM
Discussion Triple Threat II by Chris Reid (Original by Lee Renaud McCoy) Mick Molloy Electric Plane Talk 2 Nov 08, 2007 07:22 AM
Lee Renaud Slingsby Tutor plans and short kits mmartin55 Scale Sailplanes 9 Jan 31, 2006 07:56 PM
Grand Espree by Lee Renaud CHARLIE BRITT 7 Aircraft - Sailplanes (FS/W) 8 Jan 04, 2004 09:06 PM
