This thread is privately moderated by subsonic, who may elect to delete unwanted replies.
Jul 29, 2013, 03:34 AM
www.chargedrc.com.au
cdis's Avatar
Hitec Aurora 9 Tx + 9ch and 6ch rx
SOLD
This radio is in great condition. Got it to try programming crow brakes during a short and expensive glider phase and more recently as my FPV radio. I've used it for a bunch of other aircraft since then but I have too many Spektrum receivers to warrant making the change to a different system. Almost all of the clear covering on the radio is still in place including over the display/touch pad.
This is an awesome radio - feels great on your hands, switches are in great spots and you can swap between mode 1, 2, 3 or 4 really easily. Love the assignable switches (just don't forget which is set to tow release and which is air brakes....)
Comes with a 6ch and 9ch rx, the neck strap balance adapter, a bunch of stylus' if you have big fingers like me and the HPP-222 programmer (cost me $30) for upgrading firmware and setting fail safe settings. I've upgraded everything to the latest edition of firmware.
Also comes with a 2s LiPo as the original NiMh pack had seen better days - LiPo lasts for a whole day of flying without even getting close to 50%.
Original box and manuals included.
If anyone is considering this for a medium range FPV radio I've already set the failsafe on the 9ch rx to work with a APM 2.5 board (works flawlessly) and I've had mine out to nearly 2km with no issues or lag.
$350 pickup or + post at buyers expense.
Jul 29, 2013, 03:47 AM
cdis's Avatar
Eagletree V3 E-Logger
SOLD
Amazingly useful device this. I got this back before FPV and used for measuring voltage/current draw on my vehicles. Main use was setting up my offroad 1/8 scale electric buggies and truggies for competitive racing. Really useful to do a race then plug in to check out how your power usage went and where you can save a bit of juice. Also great for aircraft where you have a bunch of other stuff (LEDs, data transmitter, FPV gear, pan/tilt servos) running of the main battery. This baby will measure your power usage over the whole flight and among other things lets you make a very educated guess of estimated flight time.
I can't find any info but from memory the difference between this is less memory onboard storage for data, and lower sampling rate.
$50 posted.
Jul 29, 2013, 03:55 AM
turnigy nanotech 4s 4500mah
Hi selling 3x turnigy nanotech 4s 4500mah
35-70c lipos
less then 10 cycles each and always balanced slow charged.
Still like new.
SOLD
Jul 29, 2013, 08:55 PM
cody069's Avatar
SOLD
For Sale AtttitudeSD Goggles
Kit Includes:
AtttitudeSD headset (with integrated 5G8 RX and HeadTracker)
250mW 7ch 5G8 TX
Filtered balance lead adapter
2p 3dBi 5G8 antenna
3m AV cable
Futaba data cable
Zipper carry case
Lens cleaner cloth
Description:
Description:
Good condition , little use. $300 posted
The ezUHF data cable isn't included, was used to make a another cable.
Jul 29, 2013, 11:47 PM
Upside down, downunder in Oz
Moby58's Avatar
SOLD Rc Tunnel hull boat (hull only)
Hi guys,
Have an old tunnel hull radio controlled boat for sale.
Got off a mate years ago and has just been taking up room in shed, so has to go.
Hull is 104cm long x 40cm, fibreglass, has rudder, tube for drive shaft (but no drive shaft), a tank and a couple of props.
The radio box has a couple of servos, but not sure what condition they are in.
The mounts look like it may have had a petrol motor in it.
Other than a few marks, the hull looks good and strong.
Pickup only.
*** SOLD ***
Jul 30, 2013, 02:30 AM
building building building!
aerophilia's Avatar
Sold
Jul 30, 2013, 04:46 AM
Moby58's Avatar
SOLD EagleTrees Seagull PRO Wireless Dashboard Flight System
Hi guys,
Bought this a while ago and only used once or twice.
Has a lot of extra sensors.
EagleTrees details here
Flight Data Recorder Pro
Seagull Wireless dashboard
900 MHz transmitter
100 Amp electric expander
Couple of cylinder head temperature probe kits
Brushless RPM sensor
Several RPM sensors with magnets
Motor temperature sensor
Just missing the pitot, as its glued in a plane
HK have this (with less sensors) for $350 see here
**** SOLD ****
Jul 31, 2013, 01:06 AM
Moby58's Avatar
**** SOLD **** Radian Pro powered glider
Hi guys,
Shed clear out.... Still cant move in it
Parkzone Radian Pro
This is the BNF version with 6 servos and 6 channel Spektrum receiver
Complete with manual, battery & spares (2x props, 2x prop adapter/spinner & firewall)
Some damage at front that has been popped out, and new prop,spinner, etc added.
Cant find the wing spar, but is 10mm (I have the offcut of the 10mm carbon tube I bought to replace the stock spar)
Video from Southern River here
SOLD
Jul 31, 2013, 01:17 AM
Moby58's Avatar
**SOLD** Seagull Models E-Pioneer electric plane
Hi guys,
more stuff to make room in shed.
This is a Seagulls Models E-Pioneer trainer, that I have modified to a tail dragger so I had no nose wheel in camera shot (when cam slung underneath)
Includes a Turnigy C3536 1100 motor and some big ESC (cant remember what size). Will fly on 3s or 4s (I was using 2200mAh 4s)
Includes servos and manual.
61", full details here
SOLD
Jul 31, 2013, 01:23 AM
Moby58's Avatar
*** SOLD *** Spektrum DX6i Tx Mode 1
Hi guys,
unneeded transmitter
Spektrum DX6i Tx, Mode 1 (can change to Mode 2 if ya need)
In box with manual.
Can supply Spektrum or Orange receivers if ya need some (Extra cost).
SOLD
Jul 31, 2013, 01:29 AM
Moby58's Avatar
*** SOLD *** ARF Predator
ARF Predator
Hi guys,
More clear out again.
Got this ages ago off my brother, but just taking up room.
Only had the tail fins glued on.
Once again, the 'wing spar' Gremlins have stolen the wing spar.
Has manual and tail cone (not shown in photos)
74" span
SOLD
Jul 31, 2013, 09:11 PM
Build Something
subsonic's Avatar
Futaba 10CAP transmitter and accessories - $Sold
GONE my Futaba T10CAP transmitter.
This is an amazing radio, and to be honest I shouldnít be selling it. Iíve bought a 12FG to replace it, which I am struggling with. If I sell my 10C though, Iíll stop wanting to go back to it. I will miss its backlit screen, easy menu navigation, ten character model names and big battery, all of which the 12FG does NOT have, but hey, Iíve got to move on right?
Included in the sale is:
- Futaba 10CAP transmitter
- Futaba FASST TM-10 module (C-ticked)
- Eneloop battery pack professionally built by Andrew at Falcon Gliders
- 16k Campac module for memory expansion
- Neckstrap balancer
- Futaba factory charger
You can look up the detailed specs of the 10C yourself, but the things I like about it are:
- I have never found the limit to its programming options. Iíve flown everything with it from micro BnFís to giant scale, to DLG and slope, FPV multirotor and fixed wing with it. (It does those heli things too, apparently)
- The module means you can run any kind of protocol. I have used Dragonlink, Spektrum and Futaba Fasst. There are many other options.
- For FPVíers, you have 8 Channels of PPM input, which means you can run a headtracker on any channel via the trainer port.
- The 2000mah Eneloop pack gives an honest 10 hours of transmitting time on Dragonlink, and more on Fasst, with zero self discharge at a voltage that the radio was designed for.
- You can set it to whatever mode you want with a simple spring / slider swap and menu setting change. (I can do that for you before sale if you want)
This one is in excellent condition. I look after it carefully and it is always in its case. Itís never been wet, dropped or raced. My case is not included in the sale though.
I got a good deal on the 12FG, so Iím letting the 10C go for just $400 pickup from my place in St Ives or Mascot, Sydney. Add $15 for postage Aus wide.
Subsonic
Aug 01, 2013, 03:44 AM
Damian Couzoff's Avatar
Pat teakle Pik 20-3.75 metre scale glider.
Sold.
Aug 02, 2013, 01:50 AM
k2roo's Avatar
Sold sold sold
SOLD
Hi guys, I just upraded to a DX8. I am selling my DX6i which is about 6 months old and in beautiful condition. Comes in original box with charger and manual. Nothing is broken. A1 condition. I fly everything from a 90mm jet to an extra 330 with this TX.
$100ono or willing to swap for a couple of 6s 5000 lipos (not to many cycles of course).
Pick up only or I can deliver within Melbourne.
Aug 02, 2013, 06:58 PM
Helis for sale bargain!!!!!
SOLDup for grabs is my slightly used helis top condition month used.
Blade mcpx bl bnf almost bnew, complete w box, tail upgraded to a solid tail boom used twice with extra landing skid and brand new battery , $150 + SHIPPING
item is coming form port Macquarie NSW call or message me for faster transaction
0477431621 Carlo.
Alert AUS For Sale Thread narcas Australia 3166 Jun 27, 2013 07:38 AM
Video Parkzone Radian on shark patrol in Aus warrenlead Sailplane Talk 1 Feb 11, 2013 04:00 AM
Question Sticky removed - AUS For Sale thread narcas Site Suggestions / Complaints 4 Jun 19, 2012 09:20 AM
Alert $$$ Aus 4 Sale Thread $$$ **WILL BE REMOVED** GuyP Australia 1 May 03, 2006 11:22 PM
