Bill |
RCSettings.com is a good place to start looking for heli setups. Here is a link to the heli page: http://rcsettings.com/index.php/view.../4-helicopters. See if you can find what you need here.
i am trying to set throttle curves for different flight modes and i have 2 flight modes. one flight mode the curve is set at 60 on the top end and the other flight mode i have the curve at 100, but there is no difference in the motors rpm in either mode, am i doing something wrong? in the throttle mix i have the weight set at 100%.
can anyone tell me how to get the sp-flvs voltage sensor and the readings on my telemetry screen to match, right now they are off a bit. Do I need to calibrate the transmitter first? If so, can someone explain how? My frsky sensor shows 3.8 and it shows something different on the A2 channel on the telemetry screen on the TX.
Thank you! Sorry Admin, I put this somewhere else on the forum and realized it was in the wrong category. |
i appreciate any help! im still learning opentx. |
First thing I see is a throttle mix (ch1) with several lines, but no switches to change between lines. I see that the lines are set to be active with particular flight modes, but I'm not sure that invoking the flight mode will switch the throttle lines. I've never tried to change lines this way -- I've always coupled a switch -- so I'm not sure. Hopefully others will see more than I' Heli's make me dizzy. EDIT: I did some testing and it appears that you must include the switch in the mix line. This is how I've always done it -- but I wanted to be sure there was not another way before I got definitive. |
i normally use the switches in the mixer too but i got this eepe from pmackenzie and i tweeked it a little. it will go from normal mode to the first flight mode 'idle up' and thr_hold is working also , so i will assume the flight mode switch is working but there is no change in rpm on the second mode. i am still unsure if the curve will change the motor rpm or will i have to change the weights in the mixer page? if the curves would not change it then that would make much sense.
Here's a simple one for y'all
I have two models that are giving me an issue on binding. I have a 450 clone heli using a Spektrum AR7610 and a Bixler using an orange 6-channel RX. The Taranis has an Orange Module for use with my Spektrums.
I have to repeatedly re-bind with the Bix or the 450 whenever I bind with one or the other. So, if I want to fly with the Bix, if it was the last plane I flew with, everything is fine. However, If I fly with the Bix and then want to fly with the 450 clone, I have to re-bind with the clone. If I then want to fly the Bix, I have to re-bind with it. I am using PPM and 22.5 ms for both, but i"m not anywhere an an expert at this. I also have a couple of hexas that are using the X8R and have no problemo with those. Any ideas? It's okay to make me feel stupid Thank for any help you can offer. (FYI I started reading from Page one on 04/16 and am up to page 325... I plan to be all caught up on June 23 of this year maybe hehehe) |
to me it is easier to assign a switch from the mixer page as you suggested. |
Thread Tools | |
Similar Threads | |||||
New Product | FrSky Taranis - 16 Channels, Full Telemetry, RSSI | Rotozuk | Radios | 55922 | Mar 24, 2024 11:51 PM |
Discussion | FrSky Taranis - Owners thread | mud99 | Radios | 2160 | Jun 21, 2020 06:25 AM |
Question | FrSky Taranis - assimilating web info | mcshaz | Radios | 10 | Sep 10, 2015 02:34 PM |
Discussion | is the FrSky Taranis next step after Turnigy 9X 9Ch | tormodnt | Radios | 3 | Nov 30, 2014 07:58 PM |
