Jan 21, 2014, 05:01 AM
Master of the figure 9
punkindrublik's Avatar
Originally Posted by serjuro
Thanks man..........I might buy a Taranis, after all...........LOL
You should most definitely.
And just to be very clear; it talks to you, it doesn't beep
DONATE to OpenTx -
https://www.paypal.com/cgi-bin/websc...=DJ9MASSKVW8WN
Jan 21, 2014, 05:15 AM
Tomkfly's Avatar
Flashing lights
DAVE
Attached, simple set up for flashing lights using a single HK switch.
Note the slow settings in the mixes. you can alter them to speed up or slow down the rate,
Jan 21, 2014, 07:14 AM
F550 Flyer
Fatlab's Avatar
Originally Posted by Tomkfly
DAVE
Tom,
That's ideal as I'm looking to have LED strips around the arms of my hex-rotor which are well within the power tolerances of my current configuration. The second light channel is to power 4 x 3W LEDs to assist with long distance orientation. From what I've been reading, these LEDs get very hot even though they have a metal heat sink so one option I was looking at was having them flash with a 50% on 50% off cycle to both reduce consumption and heat build up.
Dave
Jan 21, 2014, 07:24 AM
Tomkfly's Avatar
Originally Posted by Fatlab
Tom,
Dave
Here is a simple set up to flash lights alternatively. Adjust the Custom Switch values V1 and V2 for different speeds. Uses 2 switches.
Tom
Jan 21, 2014, 07:26 AM
Fly,crash,glue,repeat!
Jake Bullit's Avatar
Any update on the FLVSS setup video Scott?
Jan 21, 2014, 08:32 AM
Bill Smudge's Avatar
Use of Turnigy 9X compatible receivers
Hello,
Probably a very silly question.......
I have Turnigy 9X version 2 and bunch of receivers that are compatible with it.
I would like to continue using all of the receivers with the a Taranis, they have been very reliable. What would be involved to make this happen?
Bill
Jan 21, 2014, 08:35 AM
Row 0, Seat A
G550Ted's Avatar
Originally Posted by Bill Smudge
Hello,
Bill
Buy and install a FlySky TM0002 transmitter module. Check eBay, under $20.
Ted
Jan 21, 2014, 11:04 AM
scott page's Avatar
Family Emergency has preempted everything.
Jan 21, 2014, 11:06 AM
scott page's Avatar
Originally Posted by TayNinh68
Soo much minutea dealing with other minutea ...dealing with legacy systems, all trying to catch up as it were. SOO much of this thread, is actually dominated by stuff that is NOT Frsky dominated. So perhaps yous guys that consider yourselves to be Futaba or Spekturm experts .. we are illiterate and we don't care. So start your own thread. Nothing personal .. just tired of pages and pages of alltj"canI akemy XXXwirje wumaybet ,, yadayads .. making Taranis working your old legacy systems.
It's already been done. Now the new threads just need to be used.
Jan 21, 2014, 11:08 AM
As it should. I hope everything is OK, best wishes for whatever the emergency is. Take care of the important stuff.
Jan 21, 2014, 11:19 AM
dhardjono's Avatar
Need help with sbus to use 16 channel
Originally Posted by dfrazier
Cool. So according to the manual for the X8R, I have to put jumpers across the signal pins of both 1&2 and 3&4 to select channels 9-16 and telemetry. Am I correct?
where i can get jumper it did not come with my trannis kit can i use a regular cable to use for jumpers. Question 2 i set the channel range to 1-16 on the tannis. Can i use this cable on this picture for jumpers?
Jan 21, 2014, 11:26 AM
Breaker of Things
ppridday's Avatar
In the kit with the case the jumpers are in the package with the keys.
Cheers,
Paul
Jan 21, 2014, 11:27 AM
dhardjono's Avatar
Cheers,
Paul
Wow thanks i just check it there so i just jump 1&2 only or both 1&2 and 3&4 ?
Ok done that now how to set to mode 4? any one help please
Jan 21, 2014, 01:04 PM
Quadaholic
--Oz--'s Avatar
Tom,
Dave
I run the HK 3W leds at 150mA (not at the so called 300mA rating), if you put the leds out on the arm under the props they are fine on all the time. Bright daylight can be seen 1/4 mile away, at night at least a mile.
Jan 21, 2014, 01:29 PM
F550 Flyer
Fatlab's Avatar
Thanks Oz, that's useful to know. I know that the LEDs have around 120 degrees viewing angle so what I was thinking of doing is mounting them on the uprights under the motors on the F550 with two reds on the rear arms so that they are facing across each other but offset by the 60 degree angle of the arms and the same with two white one on the front arms. If that does not work viewing wise I was thinking of mounting them pointing straight down at the ends of the arms. As my biggest problem is when I have the craft high up and can't make out the difference between the front and back.
I am planning on using MR16 LED drivers powered from the 4S flight batteries, hopefully that way I won't need a 3.3v UBEC.
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 55426 Yesterday 07:52 AM
Discussion FrSky Taranis - Owners thread mud99 Radios 2160 Jun 21, 2020 06:25 AM
Question FrSky Taranis - assimilating web info mcshaz Radios 10 Sep 10, 2015 02:34 PM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 3 Nov 30, 2014 07:58 PM
