Latest version of "serial monitoring mod" BLHeli firmware - RC Groups
This thread is privately moderated by sachiho, who may elect to delete unwanted replies.
Jun 15, 2013, 02:05 PM
Idea
This is the latest version of "serial monitoring mod" BLHeli firmware.
This is experimental mod. and I have tested only for XP7A-Main and Oversky double ESC-Main.
  • Switched to RKit-51. There is no need to modify notation.
  • 1200bps achieved by using "averaged divider" 6.5
  • Deleted monitor of governor errors.
  • Added monitor of ADCvalue, flags1.
  • Added checksum.
Many BT modules do not support lower than 1200 bps.
Therefore, the support of 1200 bps was important.
In order to obtain 1200 bps from (1/128us = ) 7815 cycle, you have to carry out dividing by 6.5.
I realized this by changing 6 dividing and 7 dividing for every bit.
But, code size have become too large. It can not be linked for some BESC.
Now, 10 bytes of packet is transfered.
Their contents are blow.
  • 0: Character 'U'
  • 1: Requested_Pwm (for throttle?)
  • 2: Governor_Req_Pwm
  • 3: flags1
  • 4-5: ADCvalue (for batt. voltage. seems to not working for some BESC)
  • 6-7: Comm_Period4x (for motor speed)
  • 8: reserved
  • 9: checksum (simple sum of byte0-8)
I think that we should determine the contents of the packet in the near future.
Is it good to see which information otherwise?
And Requested_Pwm does not seem to be a throttle surely.
Is there any better variable?
Jun 22, 2013, 06:10 AM
Great work! It's a pity that code becomes too large, there is surely not much room left before the 8k limit is reached.
When it comes to variables, I think your choice is mostly good.
Requested_Pwm is the throttle input value and is important.
Governor_Req_Pwm is basically the same value, except that it's change rate is limited so that governed headspeed changes become smooth. Probably not so interesting.
I think Current_Pwm_Limited is an important variable. This is the actual power that is applied to the motor.
And battery voltage and motor rpm are important variables.
Steffen
Jun 23, 2013, 05:11 PM
Thank you for the advice.
It is the perfect information for me!
I will monitor "Current_Pwm_Limited" instead of "Governor_Req_Pwm".
And next, I try to make code size smaller.
However, the again same problem will arise by a future function addition, even if code size is settled in 8kB at present.
Discussion Charge Monitor lost serial Thermal Hobby Hitec/Multiplex USA 1 May 05, 2013 09:59 AM
For Sale NIP Turnigy AE-30A ESCs flashed with BLHeli Firmware ross_badger Aircraft - Electric - Multirotor (FS/W) 0 Apr 02, 2013 05:54 AM
Discussion what is the latest firmware version for Eagles eyes FPV station? WBFlyer Eagle Tree Systems 1 Mar 26, 2013 12:54 PM
Sold Dragonlink rx latest version firmware Kloner FPV Equipment (FS/W) 5 Jul 18, 2012 09:34 AM
