Jun 11, 2013, 05:34 PM
Aviation Maintenance Manager
carrera mike's Avatar
Build Log
MITSUBISHI ZERO by ESM, Build.
ESM Zero. 88.7" Wing Span.
Finally got her today from TBM of FL.
This will be my very first warbird build, so suggestions are very much welcomed.
Ordered the factory electric retracts. TBM recommends DA-50 or DLE-50 for engine. Leaning on DA-50
Need suggestion on kind/brand of servos to use for the primary flight controls. Would like to install RELIABLE and BEST Quality servos.
Thanks in advance.
Jun 12, 2013, 05:24 AM
Zero's are terrific flyers! You will enjoy it. Go for the heavier of your engine choices. You will need nose weight. As for servos, I have been using the ones sold by Value Hobby, on page 3 of that category; TowerPro MG946R. I have had no problems with these for several years.
Enjoy your Zero!
Jun 12, 2013, 05:26 PM
Enjoy your Zero!
Thanks! Great point on the engine weight. Much better to have the weight on the engine than adding lead.
Really looking forward to this build but will not rush it. I want it done right.
Jun 12, 2013, 05:27 PM
flying weight would be around 18~20lbs, what minimum torque of the servos I should get?
TIA
Jun 13, 2013, 12:15 AM
Closed Account
Nice looking kit. I've been looking at that one myself. I wonder if the XZY 53cc twin would fit? What's the width of the cowl where it joins with the fuselage?
I think any metal gear servo around 100 oz/in or more of torque would work OK. I've had good luck with Hitec servos. I have HS-985MG servos in my 83" FW-190 D9 on the elevator and ailerons and they are great. For the flaps, I went with HS-645MGs as they don't need much speed. I'm using LiFePo4 batts from Hobby King with no regulator, and the servos like the 6.6 volts the deliver. I'd recommend servos with less than .20 sec/60 degrees for the ailerons and elevator.
Jun 13, 2013, 09:50 PM
Thanks! I'll measure the cowling.
Had a lot of research done today on servos plus help from some vets here.
I really like Futabas but looks like I'm going with the Savox digitals + Titanium Gears. They have tremendous torques too.
Jun 13, 2013, 09:51 PM
Tonight I was able to fuel proof the firewall and front formers with 20min epoxy.
Jun 14, 2013, 05:30 PM
TGIF! Able to work on the wings and installed the aileron and flaps, plus getting them set up for the servo and horn.
Jun 14, 2013, 05:32 PM
Found a test pilot who's brave enough to do the functional check flights in a couple of months.
Jun 16, 2013, 11:00 PM
Closed Account
Looking good so far. That pilot looks like he means business!
Jun 17, 2013, 09:01 AM
Too windy to fly? Lets surf
w1nd6urfa's Avatar
Mike, nice looking Zero, subscribed to your build log.
One safety tip: the wood blocks that act as servo mounts for ailerons and flaps may get torn off with vibration and flight forces. I use screws to secure them to the ply hatch.
Jun 17, 2013, 09:07 AM
He sure does . and he looks like th efamous ace Saburo Sakai.
Jun 17, 2013, 09:09 AM
Thanks, I do need those tips. This is my first build. Appreciate all the info.
I'll do that and also thinking of screwing and strip of popsicle stick on the backside to tie both of thos blocks over the servo.
Jun 18, 2013, 12:18 AM
Closed Account
Blue Loctite is your friend on metal on metal screws! Instead of gaskets on the mufflers, use Ultra Copper RTV.
Jun 18, 2013, 02:13 AM
"Fly Low, Fly Fast, Turn Left"
DanDaMan007's Avatar
Savox servos are awesome, I run them too. They do use a lot more juice than the average HV servo. I run a 2100mah 2s lipo on them with good success.
Latest blog entry: Miss Foxy Lady eBuild
Build Log Electrifying KMP/ESM's Hawker Typhoon (The Sloooww Build) Orvis Glow to Electric Conversions 253 Jul 24, 2017 07:17 PM
Discussion Scratch build of the Zero arjundogra Scale Fuel Planes 18 Mar 14, 2014 09:30 AM
Build Log Spitfire Build / Zero Replacement ( Build More) 67econoline Slope 306 Nov 28, 2013 02:33 PM
Wanted Pilot Quick Build Zero pics -Plastic Cowl etc checkprop Aircraft - Fuel - Airplanes (FS/W) 0 Jan 18, 2013 01:09 PM
Discussion TROY Build models -now selling ESM -low prices Ldm Fuel Warbirds 23 Aug 30, 2009 12:37 PM
