This thread is privately moderated by rcgreaves, who may elect to delete unwanted replies.
Jun 11, 2013, 04:40 PM
Trader Rating: 80
Private Pilot December 2018!
rcgreaves's Avatar
For Sale
LPU 53589- Sig Glow/Gas Field Box w. Dynatron and more
7/2/2013 local pick up please!
Built and clear coated from a kit, this Sig Field Box was a labor of love back when I flew glow power. If you are new to the hobby it may be exactly what you need.
$50 Local Pick Up 53589
Includes:
Sullivan Dynatron electric starter. This is what I'd term an investment grade starter. about $80 new I recall. 12/24 volt, upgradable for spinning very big engines.
one gallon gasoline can, hand pump, tubes and fittings for fueling gassers.
Sub C battery powered glow ignitor with wall charger and belt clip mounted in the caddy. (battery is installed,works but is old- plan to replace it. SOOO nice to not have a wire in the way of the prop.
Included too is a long wired twist fit glow ignitor that powers off the side panel.
4-way glow plug wrench with an OS "F" model 4 stroke plug worth about $7
Sullivan aluminum glow can cap with syphon tubing and clunk
Sullivan electric glow fuel pump, and fittings.
Sig power panel for charging receiver or transmitter packs- custom wiring plugs into the panel.
Chicken Stick- Hobbico. The safe way to hand prop a glow engine.
Customer Master Switch is fused and runs off 12v gel cell or motorcycle sized 12 v battery-not included.
Posts on side are power poles for 12v chargers, starters etc
Plane anchor- This is a custom made item I picked up somewhere out west....Essential when starting or running up engines on the ground. I have the scars to prove it's value!
Tachometer- needed for dialing in peak and idle rpm or for logging performance.
I don't wish to split this up, too heavy to ship. Local Pick up 53589 Stoughton WI.
Gas plane field box ,brighton mi 48116 LPU jkx250 Non R/C Items (FS/W) 2 Apr 19, 2013 07:52 AM
For Sale Sig Rascal 72" for glow or electric LPU REDUCED 125.00 porterfield pop Aircraft - Electric - Airplanes (FS/W) 1 Feb 15, 2013 04:02 PM
Wanted Field Box w accesories for first glow plane. Mister Gassy Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 22, 2012 08:05 PM
Sold Complete Field box for Glow - LPU DFW TX area blueapplepaste Aircraft - General - Miscellaneous (FS/W) 2 Dec 30, 2011 05:52 PM
For Sale Complete Field box for Glow - LPU DFW TX area blueapplepaste Aircraft - General - Miscellaneous (FS/W) 0 Dec 09, 2011 11:02 AM
