This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jun 10, 2013, 11:55 PM
Jack Crossfire's Avatar
High speed quad flight
There was much hyping of a 30m/s or 67mph flight mode in Arducopter at the AVC, but so far there have been no videos of this mode controlled by autopilot. 4 months ago, there was 1 blurry video of manual high speed flight of a quad.
ArduCopter V2.9 - Stabilize at high speed (0 min 57 sec)
An autonomous 67mph flight of a quad would take quite a change from the standard helicopter hover code. It would need a transition from the vertical mode to the horizontal mode with only a slight tilt for lift. This is the hardest part for tilt rotors. They usually have a gradient where the feedback from the hovering mode is blended with the feedback from the horizontal mode which is running simultaneously.
The well known hovering mode is:
forward speed -> forward/back balance
turn -> clockwise/counterclockwise balance
altitude ->throttle
sideways slip -> left/right balance
The horizontal mode would be:
forward speed -> throttle
turn -> left/right balance
altitude -> forward/back balance
sideways slip -> clockwise/counterclockwise balance
Basically, it locks the forward speed to a constant value. There's also a new requirement for coordinated turns by synchronizing sideways slip & asymmetric thrust.
The problem is it takes a very large area & a high altitude or a parachute to test horizontal mode. It's not something a private individual can afford. The testing would begin with a human putting it into horizontal mode & then engaging autopilot. The horizontal mode is required if a quad is to replace a fixed wing.
Jun 11, 2013, 12:32 AM
slebetman's Avatar
The Kickstarter funded Quadshot have done this quite successfully:
http://www.kickstarter.com/projects/...lis-and-planes
http://transition-robotics.com/
Flite Test - Quadshot - REVIEW (14 min 52 sec)
Help! Quad has high speed oscillation after crash bambam922 Multirotor Drone Talk 1 Jan 07, 2015 07:09 AM
Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo DPage Aircraft - General - Radio Equipment (FS/W) 0 Apr 28, 2013 02:11 PM
Sold New Futaba S9153 high speed high torque servo, new in box, $70 shipped. Mike Fortune Aircraft - General - Radio Equipment (FS/W) 1 Apr 26, 2013 01:20 PM
Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo DPage Aircraft - General - Radio Equipment (FS/W) 0 Apr 14, 2013 02:37 PM
Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo DPage Aircraft - General - Radio Equipment (FS/W) 0 Mar 31, 2013 02:54 PM
