The Mobius 1 ActionCam Support Thread (Posts #1-#7 mandatory reading!) - Page 1391 - RC Groups
May 16, 2018, 09:42 AM
JLT_GTI's Avatar
My Mobius is having a very short on time on home recording over a table .. and it seems heat related.
If you put it to record .. after less than 5m the yellow light gets fixed and its not recording and the video file is lost.. you can turn it off and on again and record again.. and it seems quite warm.. not very (can touch without problem) but more than warm
however if you blow air over it it works much longer.. the heatsink is hot..so it seems its making proper contact with the board or otherwise it wouldnt get hot.. i tought it would be a battery issue.. but swaped in a brand new 800 (original is also 800) battery with same results..
May 16, 2018, 05:22 PM
Since heat related, sounds like broken/poor solder joint somewhere... could be anywhere. I would reseat the lens cable first off, but you might need freeze spray to troubleshoot the board with all guts out of the chassis. Not much help as all this is common for this kind of problem.
May 16, 2018, 05:31 PM
Dance the skies...
Tom Frank's Avatar
Originally Posted by nahoku
Yes, you can use the syscfg file, but having a file created with set parameters on a computer is basically the same as setting the camera up before I leave home. The app allows for making changes on the fly in the field while using your phone or tablet....
You may have missed my point. If you have a separate card for each of your favorite settings with the config file on each one with it's "read only" flag set, you can change to any of those settings over and over in the field without a computer or phone APP by simply inserting the card and writing the config to the camera. It's not as flexible as a phone App where you can mix and match settings, but if you only have 2 or three settings that you normally use, it's a fast and easy way to change settings in the field if you don't have a phone/App.
May 16, 2018, 05:50 PM
Yes, I missed your point of using multiple cards, and yes, I didn't consider it. However, the app is way easier and more flexible... besides, I don't have that many cards, much less want to label each one for different settings, or two or three, etc settings. Of course, I could just bring my laptop along on my trips, but that too is less convenient than the app on my phone.
May 22, 2018, 05:08 AM
Barry_Cole's Avatar
Just do that I do not make a fool of myself, what is an M1 Mobius, and an M2 Mobius??
BC
May 22, 2018, 06:33 AM
Bill Glover's Avatar
BC
M1 is the original Mobius, M2 is the much newer Mobius 2.
May 22, 2018, 10:18 AM
Barry_Cole's Avatar
Is there any way of telling them apart?? Not sure how old mine is.
BC
May 22, 2018, 11:14 AM
Dance the skies...
Tom Frank's Avatar
BC
There is a separate thread dedicated to the M2 here. Each thread has pictures of the cameras and changes made to them shown in the first few "InfoPosts" in each thread. Look at those and compare with what you have.
May 22, 2018, 12:10 PM
and then there is a new thread for the newly release MObius Maxi ...
May 23, 2018, 12:51 PM
mobius 2 responds once on 2 !
Hello everybody,
My mobius 2 responds once on 2 ! when I turn it on, shuter and mode button not respond, auto poweroff after 30sec in standby as well. I can just turn it off with power button, and try again this time it works.
Note: firmware version: 2.14
and it goes on like that, it works once in two ...
Thanks and sorry for my bad english ^^
May 26, 2018, 07:58 PM
Master Prop Breaker
Originally Posted by Lee
Put a piece of black electrical tape over the LED. It is light proof.
Yeah, that's what I thought but was busted by the wife while trying out the spy features of the Mobius. Black Scotch 33 is too stretchy! Dont judge, a guy has to do what a guy has to do! Should of used the GUI to control LEDs..
Yesterday, 03:16 AM
Discussion Heli Pad Review Series: SYMA X3 Quadcopter Review Heli Pad Mini Multirotor Drones 121 May 28, 2015 03:30 AM
Discussion Olypic II is under construction now Texas Buzzard Sailplane Talk 16 Aug 10, 2014 12:54 PM
Video Quad filming roller coaster under construction Brian_ Multirotor Drone Talk 1 Mar 04, 2013 01:19 PM
Todd's Tiny under construction Tres Wright Parkflyers 30 Jun 23, 2002 11:20 PM
