Sep 11, 2013, 07:20 AM
vw4style's Avatar
Florian has made a new and even more lighter Engine, the powerline micro 1015.
Specs:
Technische Daten (Motor mit Getriebe):
Gewicht 79 Gramm
Länge 60 mm
Durchmesser 22 mm
Lochkreisdurchmesser 17 mm
Wellendurchmesser 5 mm
Eingangsleistung ca. 380 W
Empfohlener Propeller: RF 16×8/ 16×8,5*
More info >> http://www.klapptriebwerk.de/produkt...j-antriebsset/
I still use the 1025 in my Supra and what a great motor is that
sorry for the bad quality
Greets Lyckele
Supra E Pro (2 min 41 sec)
Sep 11, 2013, 08:01 AM
Cumulus Altimus
FASTBEN's Avatar
Wow, the 1025 should be in this week.
Ben
Sep 11, 2013, 03:21 PM
Cumulus Altimus
FASTBEN's Avatar
Just got a call from soaring USA...1025 on its way mine reserved.
Ben
Sep 11, 2013, 04:08 PM
MSgt, USAF Ret.
Jim Frahm's Avatar
Ben,
What's the $$$$?
Sep 15, 2013, 08:02 AM
Cumulus Altimus
FASTBEN's Avatar
It is now up on Sosa's web site. What kinda amp draw should I be looking for, I see all are using a 60 Amp ESC .the more I look at this motor more i see a lehner the bottom of it has the exact soldering for changing KV....
Ben
Sep 20, 2013, 05:30 PM
Cumulus Altimus
FASTBEN's Avatar
Dahhhhh I just found it it is the lehner .
http://www.lehner-motoren.com/1015/
Sep 21, 2013, 03:16 AM
vw4style's Avatar
Ben
It pulls about 50A so a 60amp ESC is perfect. I can reccommend the YGE60, but i ám not sure if its available in the US. But any good 60A Esc wil do the job.
With the YGE Esc you have a lot of nice features, and a 5A Bec
http://www.yge.de/artikel.php?search=yge60
(it's only in german)
Sep 21, 2013, 05:38 AM
Cumulus Altimus
FASTBEN's Avatar
well I did get the HK YEP 60Amp and a YGE program card and its programming it just as it was the YGE.
Ben
Oct 01, 2013, 06:14 PM
WINS - Winch In Nose Sailplane
jaizon's Avatar
Okay, gentlemen. Who's been flying the 1025 and can you give some feedback?
Also, I can't seem to spot the gearbox ratio. Any help with that?
Thanks.
Oct 07, 2013, 10:30 AM
jaizon's Avatar
Somebody? Gear box ratio? I'd like to input some data into eCalc but can't do that without motor specs. Thanks.
Preston
Oct 07, 2013, 11:40 AM
MSgt, USAF Ret.
Jim Frahm's Avatar
The ratio is not printed anywhere so I spun the prop 1 revolution and counted 6.7 on the motor so it looks like a 6.7:1 gearbox.
Jim
Oct 07, 2013, 12:14 PM
jaizon's Avatar
Jim
Hahahah. Thanks, Jim. That's one way to do it.
Preston
Oct 08, 2013, 08:08 AM
Cumulus Altimus
FASTBEN's Avatar
Programing the cc50 lite, timing and pwm? If any info I will appreciate it.
Thx
Ben
Oct 10, 2013, 03:21 PM
Jebera's Avatar
Thx
Ben
Hello Ben,
When you have it done, please let us know what prop, spinner and RPM you're get with what batt.
I'm asking because i wanna compare with my Reisenauer 2221/10 MicrEdition 5:1
Cheers!
André
Oct 10, 2013, 04:18 PM
Cumulus Altimus
FASTBEN's Avatar
For now I have a 16x10 spinner is rfm 32-5 no twist for now, when I finish I will pull up the CC logger and will show the amp and rpm. Will let you know.
Ben
Discussion ALES, F5J and F5J Lite dharban Electric Competition Soaring-F5J/ALES/e-Soaring 206 Dec 11, 2016 05:59 PM
Sold Kontronik Geared - F5J LMR/ALES motor Kholder116 Aircraft - Electric - Power Systems (FS/W) 3 Mar 03, 2014 09:11 PM
Build Log Supra f5j paxjohn Electric Sailplanes 1 Jan 15, 2013 09:05 AM
Discussion F5J Inter Tour 2012 - Ricardo Lima F5J pguim Electric Sailplanes 1 Mar 28, 2012 10:23 AM
Discussion etti out runner 380 or tenshock 1025-13 taffy047 Racing Boats - Electric 6 May 22, 2010 08:04 AM
