May 30, 2013, 03:22 AM
glassfox's Avatar
New Product
Official Thread:New Foxtech Falcon Pro Brushless Gimbal for NEX5/7, GH2, GH3
We have upgraded the Falcon to Falcon Pro
please check the video:
FOXTECH Falcon Pro Brushless Gimbal (3 min 1 sec)
Detailed information will be added soon
My dear Fellows,
Here I present you the new FOXTECH Falcon Gimbal,
We have done many tests on it and did many improvements(if you check our early video and you can find the difference.) before releasing it.
Falcon Gimbal is a big brushless gimbal designed for NEX5/7 or smaller cameras. It features zero noise, easy adjustment and nearly full range of camera compatibility.
Parameter:
-Working Voltage range: 2-4S lipo(8-14V)
-Max Working current: 4A
-Max tilt working range: 90 degree ()
-Max roll working range: 270 degree
-Working Principle: close circuit control
-Tilt / Roll control via RC: Available
-Max Camera weight: Around 550g(heavier cam might also work)
-Dimension: 230mmx200mmx190mm
-Cam holder width: 14cm(12.7cm usable)
-Weight: 650g
-Weight with OP damper plate: 790g
-Motors used: 2208 & 3506
Falcon gimbal is deigned very strong to eliminate any possible vibration.
Originally it comes with carbon fiber damper plate, and we also supply OP damper plate made of strong aluminum for upgrade.
The Default setting will suit most cameras without changing PID setting.
Falcon Brushless Gimbal Assistant & Basic guide Download: DOWNLOAD
Beta manual download: http://www.foxtechfpv.com/product/fa...N%20MANUAL.pdf
We also made an OP damper plate to further improve its performance.
http://www.foxtechfpv.com/foxtech-fa...or-p-1062.html
The followings are some of our own test videos and more videos will follow here
How to adjust camera balance on FOXTECH FALCON GIMBAL (6 min 18 sec)
Foxtech Falcon Gimbal Demonstration (4 min 40 sec)
FOXTECH FALCON TEST 3 (1 min 50 sec)
Where to buy: http://www.foxtechfpv.com/foxtech-fa...al-p-1058.html
We will have dedicate staff for supporting this thread,
if you have any question and not willing to leave in the thread.
you can email amy@foxtechfpv.com
our other supporting staff contact :
Doris: stockinquiry@foxtechfpv.com
Victoria: victoria@foxtechfpv.com
Alex: technicalsupport@foxtechfpv.com
May 30, 2013, 04:01 AM
Hi , everyone this is AMY from Foxtech hobby , I will be support you in the thread , if there is any question , please PM me or send me emails. amy@foxtechfpv.com
BR,
AMY
May 30, 2013, 07:13 AM
bjornthans's Avatar
Any pictures with a nex-5n mounted in the gimbal with the hdmi cable connected?
If i like what i see i will order one. I think many other are looking for the same info.
May 30, 2013, 07:31 AM
glassfox's Avatar
dear Bjornthans,
we may not be able to show since we don't have a NEX5, if you check a NEX5+ HDMI is smaller than 14cm ,then it's ok.
May 30, 2013, 07:52 AM
bjornthans's Avatar
Ok. Thanks. I know the nex5 is 11cm on its own i think.
May 30, 2013, 08:22 AM
glassfox's Avatar
then 3cm should be enough for a HDMI plug
those which has a wire go out from the side should work better
May 31, 2013, 08:37 AM
glassfox's Avatar
Sony Nex7 with 18-55mm lens on Falcon Gimbal (2 min 4 sec)
a short test video of Falcon mounted with Sony NEX7+ 18-55mm lens.
May upload another one tomorrow
May 31, 2013, 09:04 AM
blushoes's Avatar
Falcon not working - dancing
Hi Foxtech / Amy
See my video here
VIDEO0076 (0 min 25 sec)
This is how it is straight out of the box.
I then used the software to check the settings, it is not same as the attached JPG
in the zip file. I set the settings to the JPG (for nex5 / 7) and this is still the same.
Gimbal dances and moves around wildly.
Whats happening?! ((((
May 31, 2013, 09:49 AM
Originally Posted by blushoes
Hi Foxtech / Amy
See my video here
http://www.youtube.com/watch?v=vISiA...ature=youtu.be
You have to have the camera mounted and balanced for any brushless gimbal to work properly. It cannot be run without the camera in place as it is needed to make it balance out. You cannot test it standalone with no camera or wit will react as per your video.
May 31, 2013, 03:20 PM
Interested
Anyone using this gimbal? Would live to hear some reviews in this...
May 31, 2013, 05:04 PM
blushoes's Avatar
i did have the camera installed and run it and it was the same.
though the camera didnt look balanced.... (cos it was mentioned this wld
work straight out of the box)
i will try balancing it
btw, zenmuse gimbal is brushless...it doesnt require balancing or the camera to be on it to level up / stop dancing
May 31, 2013, 05:08 PM
zenmuse doesn't require balancing as it is made for one specific camera and lens setup so it is pre balanced.
All these GoPro gimbals to date need the camera in place to balance, although some can come close with no camera but depends on the size of their motors and how unbalanced they are without.
BTW - "works out of the box" is a claim lots are making but few are delivering on. my MastorG barely works after hours of tuning let alone out of the box as claimed.
May 31, 2013, 06:10 PM
Albuquerque USA
Brother you buying product from china don't expect "as advertise" like the American do. They can advertise you a bull and you get a cow not surprise in that but fox tech do have good standing they not like other where they sell you stuff take the money and run. I have good business with them so far. My Mastor g is not working right like everyone have problem with it. They did offer me refund I I sent it back which I haven't done so yet because I will cost to send it back I'll play with it to see if I can get it work to help them and help other since it not their fault on the Mastor g.
To foxtech
Please make sure you test each gimbal before you send it out to save your customer time frustration and most off all save your reputation of being selling junk. I'll still buy from you again
May 31, 2013, 08:58 PM
Foxtech and bevrc should care about the problems people are having with the mastor g gimbal for gopro3, before offering another product like this one.
The "support" thread of mastor gimbal, created by Matt from bevrc, has been left unsupported with several customers unable to make their gimbal work properly. I'll also buy again from foxtech, never from bevrc, but all those issues reported in the mastor g thread has left me, as we say here in my country, "with a foot behind the line", aprehensive to take a step further.
New Product Official support thread for Mastor-G brushless gimbal Matt_2012 Multirotor Drone Talk 1055 May 29, 2017 09:55 PM
Discussion Official support thread for ARRIS CM2000 Brushless Gimbal nancy1987 Multirotor Drone Talk 1885 Jun 15, 2016 12:19 AM
Idea DIY Brushless Gimbal For GoPro & Nex5 Widelec Multirotor Drone Talk 87 Apr 13, 2015 06:19 AM
For Sale FG-100 Carbon Fiber 4008 Brushless Gimbal for Sony Nex5 NEX7 Panasonic GH2 FPV fotogear302 Aircraft - Electric - Multirotor (FS/W) 9 Apr 24, 2013 12:01 AM
