May 25, 2013, 02:22 PM
AMA 910957
EJWash1's Avatar
Electric Aero-tow Tug
Hi All,
I'm contemplating building an aero-tow tug. I don't have the smarts to design one from a blank piece of paper, but I do have a couple of plans-built designs that I think would serve the purpose. I want it to be electric-powered as not to infringed too much on the quiet environment that is enjoyed with soaring. I would also like it to be able to tow a 1/4-scale size glider.
So, my question is, am I reinventing the wheel here? Can anyone direct me to a tug that is already the above purpose?
Thanks!
EJWash
May 25, 2013, 10:35 PM
Will fly for food
davidjensen's Avatar
Aeroworks S2 Sport Cub. There is an electric on the east coast.
May 26, 2013, 03:09 AM
DS will change your life
SpeedsterDEN's Avatar
Or the easy and cheap way, buy a Multiplex Funcub, or the slightly larger and more stable Mentor.
With this set up, ihey pull 4 meter gliders, and go vertical with 1,5 kg gliders, and they dont overspeed in a vertical dive from top height after the tow.
In the rc club we have 3 planes with this set up, and they are doing 97% of all the towing.
Set up:
Motor Turnigy 4250 Brushless Motor 1000kv :
http://www.hobbyking.com/hobbyking/s...idproduct=8489
ESC: 80 to 100 amp
13x4 prop
Batt 4000 Mha 4 Cell:
http://www.hobbyking.com/hobbyking/s...dproduct=13949
Rc. Amp draw, static / flight (1 min 40 sec)
Funcup, towing 2 large gliders. (1 min 44 sec)
Graupner vintage gliders (1 min 59 sec)
Funcup towing 4 meter Simprop Solution. (1 min 27 sec)
Advance towing (1 min 41 sec)
The record for the Funcub is a 4,85 / 6,5 kg glider + the 3,8 meter 7 kg giga Wiesel from hand launch:
Funcup towing a 4,85 meter glider. (0 min 54 sec)
Giga Wiesel action (1 min 36 sec)
Funcub towing playlist:
http://www.youtube.com/playlist?list...D5tVXsDMt9HC4k
Good luck
Cheers
S
May 26, 2013, 01:29 PM
AMA 910957
EJWash1's Avatar
Great vids!
The vid from the tow plane facing rearward gave me some great perspective. I had thought about a twin tail ('H' tail) and that footage showing the behavior of the tow line confirmed that it would be an advantage.
EJWash
May 26, 2013, 10:00 PM
Onward and Upward
CatManDu's Avatar
Check out www.rcaerotowing.com.
May 28, 2013, 03:36 PM
Multi-Platform Pilot
barracudahockey's Avatar
Originally Posted by EJWash1
Great vids!
EJWash
I'm curious, but why?
May 28, 2013, 05:05 PM
AMA 910957
EJWash1's Avatar
The vid showed the tow line under the horizontal stab and the against the vertical stab. Doesn't mean a twin tail will be a solve-all, but will move the vertical tail planes further away.
EJWash
May 29, 2013, 09:39 AM
The only problem (I didnt watch the vid from work) is that the line is under the stab, thats a recipe for disaster.
As for the vertical, its no problem, it will just pop back and forth as needed.
RCUniverse Review: Hangar 9 33% Pawnee Glider Towing GoPro (4 min 0 sec)
May 30, 2013, 11:13 PM
I am starting a fun cub build for towing. I have searched and did not see a specific picture or how to set up the tow line. I can see its on top of the wing but how does the line attach? Is there a tow bar or plate on top of the wing?
May 31, 2013, 12:14 AM
AMA 910957
EJWash1's Avatar
Winghead,
IFlyTailies offers a tow plane release:
http://www.iflytailies.com/store/tow-releases/
The mechanism has its own dedicated servo so you can release the tow line from the tug if you need to - which you really want.
EJWash
May 31, 2013, 02:00 AM
In the Funcub kit there is a towcoupling, just read the informations.
And be sure to reinforce it in the wing, if you will tow big gliders, and put in a weak link in the line, or else the coupling will get loose sooner or later.
The stock one is ok for lighter foamgliders, as the Easyglider.
Cheers
S
May 31, 2013, 02:42 AM
dare to thermal
Pictures!
I think you have to show us your towcoupling in detail....
Bernd
Jun 03, 2013, 11:27 AM
RC Paraglider / Sailplanes
Charlescd's Avatar
How much do the sailplanes you'll be towing weigh ??
Jun 03, 2013, 11:32 AM
Gentle Lady, @26 oz. Of course there will be others possibly heavier but for now a Gentle Lady.
Jun 03, 2013, 11:55 AM
Charlescd's Avatar
I would go with a Telemaster electro. There's plenty of room to install electronics and you can lay down some serious power for the same price as the Multiplex. I have Multiplex Mentor and there's only so much power the airframe can handle.
If someone shows up with a 8 lb glider, you'll be able to tow no problem.
I've used a Tacon 160 on several planes and you can easily get up to 2500+ watts on 12s. For moderate towing -- 8s and a 17x8 prop.
http://www.hobby-lobby.com/6_foot_te...34835_prd1.htm
http://www.hobbypartz.com/96m608-big...335-245kv.html
It's a suggestion.
Cool 1/3rd Scale Electric Salto with Bill Hamilton At the JR Aero Tow 2013 ChuckTseeker Electric Sailplanes 0 Apr 30, 2013 07:56 AM
Discussion A club tug for aero tow? Noel Eberhardt South Bay Soaring Society 1 Jul 19, 2012 11:51 AM
Discussion aero tow Tug recomendations ozmo01 Sailplane Talk 3 Jun 19, 2008 07:45 AM
For Sale 8 ball special aero tow tug kit kevin kavaney Aircraft - Sailplanes (FS/W) 0 Jun 20, 2006 08:10 PM
Article Electric Aerotow: Towing Large Scale Sailplanes with Electric Tugs SoarNeck Sailplane Talk 3 Apr 06, 2006 03:12 PM
