This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
May 24, 2013, 05:00 AM
Jack Crossfire's Avatar
Another 3 axis idea
Basically, you need a table of some kind for each camera axis
imu2 roll
imu2 pitch
V
table
V
motor 1 PID gains
motor 2 PID gains
motor 3 PID gains
The outputs of the 3 sets of PID equations for each motor are summed to get the motor steps. The hard part is computing the table. All 3 motors have a unique set of gains in the upright position. They have completely different gains in the 2 sideways positions.
There are 2 mane gradients for the PID gains: The roll & yaw motors trade places as imu2 pitch goes from 0 to 90. The yaw motor is replaced by the pitch motor as imu2 roll goes from 0 to 90.
The 2 mane gradients aren't linear. They're a sine wave. When IMU2 is pitched 20 deg over, it adds just 12% of the roll. When it's at 45 deg pitch, it adds 50% of the roll. When it's at 70 deg pitch, it adds 88% of the pitch.
If each motor has 3 sets of gains: the upright yaw, 90 pitched yaw, & 90 rolled yaw, each set of gains has 3 parameters: P1, P2, D2, a total of 27 values need to be manually tuned. The best way to tune it is to tune the fully deflected states.
Only 1 guy outside a corporation ever got the yaw coupling to work:
3-axis Brushless Gimbal 0411 tuning PID (0 min 46 sec)
But it was still unstable when the pitch & yaw motors were parallel. Having 2 motors share the same axis is a buster. You want yaw to be stabilized as much as possible, until the yaw motor is sideways. It requires gradually taking away more & more latitude from 1 of the motors until it's rigid. The easiest solution is to always have the pitch motor control 100% of pitch, with the yaw motor tapering its gains in the yaw direction as it goes horizontal. This doesn't maximize all the available degrees of freedom of the motors.
Without the brute force kinematic search, the table has the motors fighting each other. Doing the brute force search fast enough would be real hard. No-one has tested a Zenmuse to these extremes, but it probably does it right.
Discussion UAV with a 3 axis camera? Any ideas? Reginak FPV Talk 3 Jun 13, 2014 06:02 PM
Discussion Soodohobby IFLY-CT6 Two axis AP tilt Camera Amount/Gimble for IDEA-FLY IFLY-4S Quadcopter MQ80 Multirotor Drone Talk 0 Feb 21, 2013 07:17 AM
Discussion Another DIY Gimbal idea lorenjz Multirotor Drone Electronics 1 Jan 14, 2013 07:53 PM
AXI in a GWS - Another Twist on a Good Idea PGR Parkflyers 20 Dec 11, 2004 09:45 PM
