Thread Tools |
This thread is privately moderated by N827TM, who may elect to delete unwanted replies. |
Build Log
Carl Goldberg Eagle II Twin "Franky D"
Early last year, I acquired two Eagle II boxes and a fuselage. However, I did not inventory the contents of the two boxes until Dec. 2012. Initially I thought there were two kits, unfortunately, there were not even enough parts to complete one kit. I found what was missing and 60 dollars later, I had parts to finish the kit. As popular as the Eaglet 50, 63 and Eagle II Trainers are, I decided, I did not want another trainer. I already have one, and a couple more kits in the shop.
Back in the mid 90's it was a fascination of mine to create a twin from a Goldberg Eagle II. I figured now I have the opportunity to do it. Next, I finally had to make a few decisions, Did i want to leave it a high wing or convert it to a low wing? Did I want flaps? Did I want retracts. I did a few things to help make the decision. I decided to cad the basic design of the airplane and move components (wing and tail) around until I found what I liked. I decided converting it to a low wing twin, with retracts and flaps. The name "Franky D" came from a friend (Ben). My friend Dustin reignited the spark to start this project as he had done the same thing with a couple different ARF trainers. His trainer was called the Frankin Twin, as the wing and fuse were from different kits. So, I copied the name Frankin Twin, although my components are all from the Eagle Two. When Ben heard I was doing retracts and flaps, he then called it the Frankin Twin Deluxe, and the name "Franky D" was born. I ended up doing some big mods to get it to this point. I cut the nose off from the firewall forward and redesigned the nose to accommodate a nose wheel retract. I cut wing saddles into the fuselage for the low wing. I then added a roof that blended into the fuselage. When I built the wing I added flaps, retracts and lights. I also did a lot of sheeting on top and bottom. I also fiberglassed the two wing halfs together after I put in the spar jointer. The rest of the pictures will show the progress of the build. On August 20, 2013, I maiden the Franky D. It flew awesome. Here is the link to the video.
Cheers, Tom ImagesView all Images in thread
Thread Tools | |
Similar Threads | |||||
Wanted | Need Plans for the Carl Goldberg Eagle 63 | jodymichael | Aircraft - Fuel - Airplanes (FS/W) | 5 | Aug 31, 2013 02:27 AM |
Discussion | Carl Goldberg Skylark 56 MARK II plans? | Eddy | Balsa Builders | 6 | Jan 22, 2013 09:58 PM |
For Sale | Carl Goldberg Eagle II ARF with brand new magnum engine and futaba servos | mxaexm | Aircraft - Fuel - Airplanes (FS/W) | 1 | Aug 22, 2010 10:58 PM |
For Sale | Carl Goldberg Eagle II ARF + brand new Magnum .46 engine | mxaexm | Aircraft - Fuel - Airplanes (FS/W) | 0 | May 26, 2010 09:06 PM |
