May 08, 2013, 09:33 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Dualis SW (swing wing)
This new thread has been started because the original thread for a different model morphed into this model so it was decided it may be a better option to start again … so here is the Dualis SW (swing wing)
The wing swing is very simple, very similar to the MDC F-14 … if you haven’t seen it, go to https://www.rcgroups.com/forums/show...t=769451&pp=30 and posts #104, 105, 106, 123, 125 and 126 show the swing build in detail, it should be a little easier on the Dualis as it has 2 x servos instead of one.
If you decide to give it a go, please take pics as you go and post them here … and let me know if there are any problems with parts fitting not quite right, etc.
Happy building
Plans are now available at: http://www.lockeysrcplans.com
Lockey
Wing area:
Wing loading:
Weight RTF: 738g (26 oz)
Built from 6mm Depron.
Motor: D2826-6 2200kv Outrunner Motor … https://www.hobbyking.com/hobbyking/s...dproduct=12919
Prop: TGS Sport 6x4E Precision propeller … https://www.hobbyking.com/hobbyking/s...idproduct=7936
Battery: ZIPPY Flightmax 1800mAh 3S1P 20C https://www.hobbyking.com/hobbyking/s...idproduct=6293
Speed Controller: TURNIGY Plush 40amp Speed Controller … https://www.hobbyking.com/hobbyking/s...dproduct=32065
Wing swing servos: Turnigy_S3317M … https://www.hobbyking.com/hobbyking/s...0kg_14sec.html
Elevon and Rudder servos: HXT900 9g / 1.6kg / .12sec Micro Servo … https://www.hobbyking.com/hobbyking/s...dproduct=23993
Radio: Spektrum DX7 with OrangeRx R710 Spektrum DSM2 Compatible 7Ch w/Failsafe … https://www.hobbyking.com/hobbyking/s...dproduct=35714
May 08, 2013, 09:40 PM
Lockey's Avatar
Start of the build, found one or two little mistakes but will change on the plan before posting ... changes made, unless I find more
Lockey
May 08, 2013, 10:05 PM
RC Adddict
Wilfor's Avatar
Sub'd
May 08, 2013, 11:06 PM
justj's Avatar
Subscribed
Thanks Lockey & Ken!
May 09, 2013, 03:34 AM
Ken's CAD Models
dz1sfb's Avatar
Woo Hoo!
Remember to bring the revised decals over too! Very nice!
Ken
May 09, 2013, 04:31 AM
1 can never have 2 many planes
chambo88's Avatar
sub'd
May 09, 2013, 05:22 AM
Lockey's Avatar
Originally Posted by dz1sfb
Woo Hoo!
Ken
Revised decals as requested Ken on the first post
Lockey
PS. Slight problem guys ... is it possible to have one servo going clockwise whilst the other is going anti-clockwise on a Y lead? if so HOW ?
May 09, 2013, 05:49 AM
Lockey's Avatar
Little more build today, I covered the wings with clear tape, partly for strength and also for slide ability
The ply wedge in pic 3, I cut into the wing and CF tube to give it strength as this is the pull/push part of the wing swing
Lockey
May 09, 2013, 06:01 AM
Build, Fly, Rebuild!!
Ghost who walks's Avatar
Servo reverse
Lockey
Hey Lockey looked this up and found this thread, hopefully this will have the answers you need. https://www.rcgroups.com/forums/show...d#post24708592
Ghost, along for the ride
May 09, 2013, 06:13 AM
Lockey's Avatar
Thanks Ghost, looks like there isn't an easy answer, might have to re-think this as it might not be easy for some guys to start re-soldering wires inside the servo.
Lockey
May 09, 2013, 06:37 AM
Retired CAD guy
birdofplay's Avatar
There used to be available a little inline SERVO reverser. Some even had pots for
adjustments too.
Just BING Servo Reverser
This one is a bit pricey but ...
http://www.servocity.com/html/sr10_servo_reverser.html
this one a bit to cheap ...
https://www.hobbyking.com/hobbyking/s...dProduct=17033
and another ...
http://www.rcdude.com/servlet/the-19...everser/Detail
However, A MIXED AUX channel for computer radio owners will do the job too.
Bob
Hoosier Cutout Service
May 09, 2013, 07:04 AM
Lockey's Avatar
Bob, it might just b easier to go back to a single servo like the F14, it seems to work OK so long as you have a strong enough servo
If it gets too complicated (or expensive) guys won't build it ... I guess go back to the KISS principal eh! "Keep It Simple Stupid"
Lockey
May 09, 2013, 07:08 AM
Ken's CAD Models
dz1sfb's Avatar
Idea!
On the servo arms, I am going to make the center hole net to the control horn boss. This will reduce the torsional load on the arm transferring to the servo output shaft. Need a couple of metal gear servos for this task that are in the 9g case size.
Ken
May 09, 2013, 07:29 AM
Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Lockey,
You can purchase slow motion reverse 'flap' servos which may be suitable. Look towards the bottom of this page as an example.
May 09, 2013, 07:41 AM
Ken's CAD Models
dz1sfb's Avatar
I am just going use the mixing on my Tx to work these servos, using the flap function mixed to the aux or gear channel.
Found these metal gear servos at Hobby King https://www.hobbyking.com/hobbyking/s...arehouse_.html
Should fill the bill and available at the US wharehouse.
Ken
Build Log Dualis Lockey Foamies (Scratchbuilt) 218 May 08, 2013 09:35 PM
Build Log New Generation wing FWD(-33)Aft(+45) 1 swing aero1960 Pusher Prop Jet Models 1 Mar 16, 2013 02:14 AM
Discussion Wing area and elevators on swing-wing jets mikerogers74 Pusher Prop Jet Models 3 Jul 25, 2009 08:39 AM
Dualie Voltage Clamps hall woo Batteries and Chargers 1 Apr 09, 2004 07:17 PM
