This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Apr 28, 2013, 04:15 AM
Jack Crossfire's Avatar
The EDF myth
So EDF's don't make a multirotor lift more in a reduced area. They require much more battery mass than the increased thrust they produce. The comments for the mighty EDF70 tell a tale of 60A consumed, just about the limit of a 3Ah battery.
https://www.hobbyking.com/hobbyking/s...Assembled.html
They require a 70A ESC.
https://www.hobbyking.com/hobbyking/s...k_70A_ESC.html
Each one would need its own battery.
The easiest way to get more out of a multirotor the size of a Syma X1 is to stack 2 on top of each other, connect 2 motors in series, & power it off 8.4V. You also want higher voltage for sonar range & a CCD camera.
The next step is to build a custom, brushless one. The brushless one would require custom ESCs to be as stable as the brushed one. It's quite involved.
Discussion Myth #1 - 3 bladed props give more thrust than 2 bladed ones rcmaverick Electric Plane Talk 251 Oct 03, 2016 11:32 AM
Discussion The wood prop myth..? Kimber Electric Plane Talk 60 Jun 26, 2013 07:40 PM
Discussion Another Republican myth slain Sherlock Life, The Universe, and Politics 101 Mar 03, 2013 04:40 PM
Discussion EDF myth zaskarkid Electric Ducted Fan Jet Talk 10 Jun 08, 2008 06:30 PM
Question PCM+EDF no good - myth or reality? Downwind3Zero Electric Ducted Fan Jet Talk 4 Jan 30, 2005 04:58 AM
