Jan 16, 2014, 12:20 PM
15" props
motors mystery 750kv
battery lipo 3 s ,mAH don't know yet
he develop his own flight control he call it "LittleDuck"
In the vdo
at 4:10 he look at battery indicator in his phone he said "now battery at 11.7 volt"
at 8:09 he said "now battery at 11.1 volt"
at 10:06 he said "perhaps memory full ? the camera stop recording he press record again for record second file"
at10:15 he said "now battery very low battery at 10.7 volt"
Jan 16, 2014, 12:52 PM
Youtube: TomRi25
Dr.Tom's Avatar
OMG this could be a new era...
plain lipo but some new ESC...
- Battery = Li-Po 11.1V 7000 mAh (3S-2P)
- ESC = Dragon 12A ESC (Pulse Drive Firmware V2.
** Pulse Drive Motor System (Technology form Hybrid Car)
with LiIon times will be longer too...
Jan 16, 2014, 01:00 PM
sorry I did't read the Description
Multirotor spec
- Frame = A bug flight quad rotor
- Flight control = LittleDuck MR-810
- GPS = Ublox LEA-6H
- ESC = Dragon 12A ESC (Pulse Drive Firmware V2.**)
- Propeller = 15 X 5.5 (draganfly shape)
- Radio = MC-500
Technical spec
- Flight weigh = 1.1 KG
- Current Consumption = 3.2Ah
- Power Consumption = 40 W
Jan 16, 2014, 01:08 PM
EndOfDays's Avatar
My deepest respect, that is far ahead of what I am doing.
27,5gr/W is outstanding, close to extraterrestrial.
To be honest I cannot believe this. If I see this frame, there are for sure 100-200gr to be shaved off, with my batteries, he would fly close to 4h.
best regards
Ferdinand
Jan 16, 2014, 01:11 PM
Youtube: TomRi25
Dr.Tom's Avatar
I linked this topic in comments of his video,
it would be VERY good if he coud join here and discuss a bit...
like you also noticed, it doesn't seem to be super light built, and common batteries also(LiPo)..
but less than 1A per motor is good.
...trick seems to be in ESC's... hardware or maybe even only in firmware!
hope we will get some more info
Compare PWM ESC & Pulse Drive ESC (2 min 31 sec)
Jan 16, 2014, 01:15 PM
If that is finally a sine wave esc this is a new era. The sine wave esc is far more efficient a part throttle settings. Years ago I had a discussion with Steve Nue regarding esc's and he mentioned the far superior controllers used in hybrid cars and full size aircraft. I will look for a link.
Jan 16, 2014, 01:29 PM
best regards
Ferdinand
This 2h video from far east stinks a lot
A 15x5.5 prop spinning at 2500rpm generate 300g trust but by physics need 20w power
So with ideal motor he will need 20w per motor, so 80w for stay in the air.
It is claimed to consume the half of what the 100% efficient ideal motor would be able to do.
Either he was cheating, or he is in a thermal environment for making the test ... so again cheating.
ps: Also why did use 750kv motor when he need total 2500rpm ? 1S lipo would be more then enough for get up to 2500rpm needed for hovering ...
Jan 16, 2014, 01:37 PM
Youtube: TomRi25
Dr.Tom's Avatar
ok,
but you are comparing KV/V/RPM math of our 'standard' esc's with this 'new' ones,
maybe there is needed more V for same RPM, but for shorter bursts, so average watts are so low?
guessing only...
Jan 16, 2014, 01:41 PM
ok,
maybe there more V is needed for same RPM, but for shorter bursts, so average watts are so low?
guessing only...
Why a more efficient esc should make spin the motor slower .. if motor is 750kv ... with super esc I would expect even more rpm per voltage ...
Other option could be that he did rewind the motor.
But ... for me it is looking 99.99% a cheat video
ps: Per my tools for produce 300g trust per motor with 15x5.5 prop .. it is needed 20w ... he claim to use the half ...
Jan 16, 2014, 01:53 PM
Youtube: TomRi25
Dr.Tom's Avatar
about rpm/V... how do you know he was flying at 100% power?
maybe he wanted to hover at very low throttle, for better efficiency of his ESC's?
Jan 16, 2014, 01:55 PM
There is a RcGroups member with the same name as the video post.
https://www.rcgroups.com/forums/member.php?u=284578
I sent a PM asking him to start a new thread and discuss his flight.
Jan 16, 2014, 02:14 PM
It just make no sense however you want to look at this stuff
Too many things stinks on that video
Jan 16, 2014, 02:16 PM
He is a bussy man, he is a pilot and an inventor I'm not sure he will come and discuss here in RcGroup he rarely post on our thailandmultirotor facebook page, but it will be honor if he could come and discuss with us
Jan 16, 2014, 02:19 PM
If everything checks out he will soon be a very rich man too.
Jan 16, 2014, 02:37 PM
DJI Supporter
Sid3ways's Avatar
Is this the same technology as what the MK guys are doing with their ESCs? They are releasing new ESCs with braking which sends the energy back into the battery.
I'm loving the advancements we are seeing come to light. Ferdinand, if anything you are the driving force around here to pushing the limits on what people have a hard time believing, bravo!
MikroKopter- BLDC V3.0 SpeedControl (4 min 47 sec)
Question Anyone fly with a Hacker A10-15s and a Glavak prop? r/cmark Indoor Pattern/F3P 6 Apr 10, 2013 09:45 PM
Discussion LiPo Battery Flighttime with MultiWii Jessestr Multirotor Drone Talk 3 Jan 15, 2012 05:30 AM
Shorter flighttime with a 3s Lipo, than a 2s Lipo ? SpookiePower Batteries and Chargers 12 Oct 28, 2009 02:19 PM
Discussion E550 with 15S A123 genexis Electric Heli Talk 10 Dec 17, 2006 01:05 PM
FS: Hacker B50 15S with 1/8" shaft and MEC Superbox smsgill Aircraft - Electric - Airplanes (FS/W) 7 Sep 05, 2003 10:57 AM
