Apr 26, 2013, 09:20 AM
F.Omenal's Avatar
Build Log
Lowcost Multiprotocol PPM to DSM2/NINE EAGLE
Eh everybody!
An another arduino project in my poor overclocked brain.
It s an Multiprotocol to make Spectrum-Nine Eagle-Devo-WK for my MPX royal evo.
The base is an glcd nokia with joystick, a cyrf6936 tranceiver half duplex for devo tx (9€ on hirobo webshop) and porting some big part of DeviationTX..
Many, many thank to all contributor of deviationTX project and spécial guest star for PhracturedBlue .
So, i will post the code and the scheme to make it.
i will make some video to show you how it's work.
EDIT 29/04/2013:
OK, here come the video:
Multiprotocole DSM2 and J6PRO nine eagle (14 min 50 sec)
The code will come and i post the link in the video infos. this video is in french
i make another video, and i try to speak english, but you can show subtitle.
Multiprotocole english speaking (9 min 39 sec)
for this moment the only video i have is the prototype with the lp4dsm module.
Regards
EDIT 15/05/2014
Because i lost time to find information for pinout for all rf module, i post they here.
it s may be more helpful.
now i can add a nf24 to my protocol, with NineEagle v1 and hisky, upgrade dsm.
and all in small box with 3 led and 2 bp, to have in my small arduino Tx.
Multiprotocole RC module with arduino (5 min 52 sec)
Apr 26, 2013, 10:25 AM
Hi
Your about to make alot of people very happy!!
Nice one and good luck.
Phil
Apr 29, 2013, 11:46 AM
bitchin86's Avatar
Where did you get the LCD joystick board? I would love to make one of these
Apr 29, 2013, 02:08 PM
F.Omenal's Avatar
The One i use came from Nulectronique. but this shop as disappear.
I found a board but not the same. this board have same function :http://cgi.ebay.fr/Graphic-LCD4884-J...item416c71d7e5
you can use this: https://www.sparkfun.com/products/10168 and this https://www.sparkfun.com/products/11187 with some mode on joystick you can have the same function.
Regards
Apr 30, 2013, 12:45 PM
For the LCD4884 Shield Here's a list but one on ebay looks very nice.
Thanks for doing english video
RX flashing after dis-connecting battery is normal. All its telling you is Signal was lost. If you power down TX and RX and switch back on shouldn't flash.
Apr 30, 2013, 02:36 PM
F.Omenal's Avatar
You think rx flashing meaning signal lost?
but all work perfect, esc and servo.
If i lost signal how can i have this working?
Apr 30, 2013, 02:55 PM
It's ok
When you first switch tx/rx on, no flashing. But if you switch off only rx when you power it back on it will flash. Rx is to stupid to now you removed battery. It just thinks signal was lost since it was last connected to Tx.
So it's normal to see it flash. I had specktrum rx in my trex 450 never switched off tx when i changed battery, so next 8 battery changes my rx would flash unless i switched both tx/rx when i changed battery's.
May 08, 2013, 11:20 AM
bitchin86's Avatar
What is the tx module out of? Will a magic cube work?
May 13, 2013, 09:12 AM
F.Omenal's Avatar
the tx out is serial ppm, standard for training.
it is like magic box, you can use the same plug for walkera.
in the zip file you have a schema.
the 2.4ghz module to use is this: http://www.ehirobo.com/shop/Transmit...duct_info.html
you can find it on other webshop.
If you thinking about re-use the 2.4ghz magic box module, i don't no if it's possible, maybe for DSM2 but not for Nine Eagle because you need telemetry for NE.
Regard
May 22, 2013, 08:32 AM
Hobby King have screen in stock https://www.hobbyking.com/hobbyking/s...0_Arduino.html
May 30, 2013, 05:43 AM
F.Omenal's Avatar
Ouah, it a cool price.
OK, i have make a box.
have a look.
May 30, 2013, 06:01 AM
Looking very good. What range are you getting or picture not including aerial ?
Jun 28, 2013, 06:32 AM
I have a TX module (X1TXN revB) from an old DX6 that I am trying to use with your firmware. It attempts to bind but it will not complete. During binding, the receiver light blinks slowly then goes out but it will never go solid. Any ideas why? As far as I know this module is almost identical to the one for the DEVO that has a link further up in this thread to the ehiribo shop. The module has a direct SPI interface to the Cypress chip.
Aug 01, 2013, 09:11 AM
F.Omenal's Avatar
Sorry i am back from holiday.
Ok, if it's the same module, i'm thinck the slow blinking and not go solid may be occurs in two possibilitie
the PPM signal is not correctly see. Have you the good number of channels on the lcd?
because if you have not ppm in, the led blinking slow, and go off.
the second is the module is not a correct power. or the antenna is not correctly connect.
i have some trouble with this, and it may need some update to select power out.
Aug 21, 2013, 10:34 PM
mono's Avatar
hello
if I may say so, this is a very clever project.
Not sure if I'm understanding correctly, are some protocols not working yet?
Are you planning to continue with development, as there's been no posts for a while?
merci beaucoup
Help! 3 Channel Arduino DSM2 Surface Transmitter Project Nactan DIY Electronics 11 Jun 05, 2013 12:10 PM
Discussion Arduino project -> Multiscope F.Omenal DIY Electronics 10 Apr 26, 2013 01:51 PM
Discussion Arduino project to build autopilot controlled RC plane! Ecibob Electric Plane Talk 2 Apr 25, 2011 10:17 AM
Discussion Arduino open source autopilot project TheRCEdge Aerial Photography 3 Jan 28, 2011 03:01 PM
