The Delta Receiver - Hitec, Futaba and FrSky compatible! - RC Groups
Apr 17, 2013, 02:20 PM
Rotozuk's Avatar
New Product
This thread is to introduce you to an innovative new 2.4 GHz receiver that can bind to FrSky D8/V8, Futaba S-FHSS/FHSS and Hitec A-FHSS protocols. I believe this is a first for the hobby marketplace.
The Delta receiver will automatically figure out what protocol to use during the binding process. But if that isn't enough you can manually assign the protocol during the bind process too.
While this multi-protocol is cool and all, that simply was not enough, so the Delta also offers RSSI and CPPM outputs! So not only is there a more affordable compatible receiver for the Hitec and Futaba systems, but they also have additional features.
RSSI output is for our FPV users. It allows you to see the receivers signal strength via your video equipment. This allows you to safely use your full range.
CPPM output is another powerful feature that makes the Delta very handy. CPPM combines all 8 channel into a single servo connection. This can be connected to flight controllers to reduce wire mess, a single wire feeding all 8 channels rather than 8 wires! Or use it as a wireless trainer cable or wireless sim cable. No more wires connecting your transmitter to the student's radio, or to your computer for your favorite flight simulator. Very cool!
The Delta 8 is a full range 8 channel receiver that supports transmitters that use the following protocols:
  • Hitec A-FHSS
  • Futaba S-FHSS
  • Futaba FHSS
  • and FrSky V8 & D8 (does not support telemetry data)
True diversity with the dual antennas. Antennas like most all FrSky receivers are replaceable, and available in different lengths. This allows the receiver to work in most environments, even high carbon fuselages. (available in 150, 250, 400 and 600mm lengths)
More details here:
http://www.alofthobbies.com/delta-8.html
A 4 channel version should be available soon.
-Wayne
Apr 17, 2013, 02:21 PM
Radio? Screwdriver!
I'm pretty stoked and excited about this new receiver and it's possibilities. It is possibly one of the most complex receivers out there and has taken an awful lot of work to do. I also believe the first ever 2.4GHz receiver that works with multiple mainstream brand transmitters and a very innovative product.
The beauty of it, is that you can buy a receiver to work with your existing transmitter but you are no longer locked into one single brand. So if you wish to upgrade or change over from one manufacturer to another, you don't have to go out and replace every receiver and it will also give you a chance to test and try out another transmitter without buying a whole boot load of receivers. Hence all those existing Hitec 2.4Ghz and Futaba S-FHSS users out there that want to have the new FrSky Taranis transmitter, but don't want to start buying receivers that aren't compatible with your existing equipment, you now have a great option. Not only that, these receivers are priced at a very competitive price - often around half the cost compared to the original manufacturers receivers.
Over time, I would love for manufacturers, to start integrating them into their aircraft kits to create a competitive environment in the Bind and Fly market.
Si.
Radio? Screwdriver!
As a few readers of this forum will know, I have some connection with these and so can help and assist.
Feel free to ask any questions or queries you may have.
Apr 17, 2013, 03:11 PM
Any chance of it being modified in the future to include the Sanwa/Airtronics flavor of FHSS, preferably FHSS-3?
Apr 17, 2013, 03:16 PM
Rotozuk's Avatar
Yep, and as a retailer I like being able to stock one receiver that does so many different things.
The bigger brands like to sell variations of their receivers. It is not uncommon to see a normal 8 channel receiver, then another 8 channel that has something like the RSSI port, and yet another that has the RSSI and CPPM. So in a way you can say the delta actually takes the place of 6 or more different receivers.
Great job on the firmware Simon!
-Wayne
Apr 17, 2013, 03:24 PM
Radio? Screwdriver!
It all depends on the RF chip that Sanwa uses. Hitec/Futaba SFHSS/FrSky all use the same chip (CC2500) which makes it possible to do this. Do you (or anyone else) know what Sanwa uses?
If you haven't a clue which chip that they use, if you take a high-res image of both sides of one of your receiver circuit boards it should be possible to work it out.
Cheers,
Si.
Apr 17, 2013, 03:49 PM
Cheers,
Si.
Hello,
Is this receiver's firmware upgradeable?
Arnaldo
Apr 17, 2013, 03:52 PM
Radio? Screwdriver!
Originally Posted by Mahdibird
Hello,
Arnaldo
No, its not user upgradable.
Si.
Apr 17, 2013, 04:10 PM
Any plans for one that does telemetry?
How about DSM2 or DSMx?
Apr 17, 2013, 05:08 PM
Radio? Screwdriver!
I want to do a Hitec compatible with telemetry at some point soon. Futaba S-FHSS doesn't have the facility for telemetry however.
DSM2/DSMX can't be integrated into this receiver as they use a different RF chip to FrSky/Futaba/Hitec which isn't compatible at all unfortunately.
In theory it could be possible to produce a receiver that supported Spektrum/Multiplex/Devo though.
Si.
Apr 17, 2013, 10:32 PM
I've attached three views of both sides of the 10 channel FHSS-3 receiver that Sanwa/Airtronics uses with the SD-10g tx. Anyway, I hope this helps.
Cheers,
Si.
Apr 18, 2013, 01:31 AM
Si.
Yes please
CYRF6936, the Cypress chip, so not possible to be compatible with Delta 8, sorry.
Apr 18, 2013, 01:55 AM
When will it be available and what's the price,i use Hitec Aurora 9 where the Rx's are pricey i find it hard to leave the telemetry behind even if it's just the SPC for flight pack voltage which is important,however these new products are welcome as they open up new doors.
Apr 18, 2013, 02:03 AM
Atomic Skull's Avatar
I think it's great that there' finally a S-FHSS compatible reciever out there. The 8J is a great not too expensive radio but till now you were locked into Futaba receivers with it and a FASST radio actually would end up costing you less overall.
Discussion Hitec A-FHSS compatible 8ch FrSky receiver with diversity for $22! Koo Hot Online Deals 85 Jan 24, 2015 03:23 PM
Sold frsky faast compatible TFG6-A for futaba cb100 Aircraft - General - Radio Equipment (FS/W) 0 Mar 02, 2013 07:16 PM
Discussion Is the frsky Tfr6 compatible with the futaba T6 tx wc_wickedclown Mini Helis 3 Feb 16, 2013 09:56 PM
Sold 2 x FrSky / Futaba FASST Compatible 8 Channel TFR8S Receivers - $51.80 Shipped CONUSA Left Coast DJ Aircraft - General - Radio Equipment (FS/W) 0 Feb 02, 2013 04:38 PM
Sold Futaba 7c 2.4GhZ with FRSKY TFR6 - 7 CHANNEL FASST COMPATIBLE RECEIVER Mikey 68 Aircraft - General - Radio Equipment (FS/W) 1 Jan 07, 2013 05:25 PM
