Heavy Duty Tracker? - Page 2 - RC Groups
Apr 24, 2018, 01:28 PM
Originally Posted by Martin Y
Try a counter weight on the tilt. Will stop the the high current draw just to hold in place.
That's a good idea, as the tilt servo still seems unhappy even after cutting the arm back a bit.
I'm just not sure how I would mount a counterweight onto the tilt servo using the existing setup.
Apr 24, 2018, 07:37 PM
Okay so I have managed to devise a way to attach a counterweight to the arm of the tilt servo.
It is now definitely a major improvement over the stock configuration as I no longer hear any complaints from the servo. See attached photos.
May 15, 2018, 06:42 PM
400' ..... NOT
Martin Y's Avatar
That'll work
Latest blog entry: 1280mhz vs 1090mhz
May 15, 2018, 10:50 PM
NutBag's Avatar
I needed a counter weight on mine also once I fitted the bigger Vulcan.
Just made a simple alloy angle bracket with a block of Lead attached and made length so it does not hit anything during rotation right through to vertical.
I also changed the "tilt' gearing to the highest I could get from servocity... the pinion is now tiny.
May 15, 2018, 11:07 PM
NutBag's Avatar
Here's the one with Eagletree setup and Gatling.. find it doesn't really need the counterweight with the antenna attachment arm cut as short as possible.
Both my trackers have worked faultlessly for over 5 years now, couldn't be happier with them.
Cables are a little messy here, was trying out the Clearview Rx or the first time.
Latest blog entry: Build Pics
May 15, 2018, 11:22 PM
Are those the VSWR numbers for each frequency in the top left corner of the antenna?
Also, how do you like the Clearview XLR? Does it seem to be much of an improvement compared to other 1.3 receivers? My understanding is that for it to work best you need two identical antennas, although if you just want it for diversity then I suppose one directional and one omni is okay too. My main interest is long range so I would probably hook up two directional antennas of identical gain.
It would be nice if someone did an actual long range test of the XLR, side-by-side with a conventional receiver.. After all, that is what the XLR stands for- Xtreme Long Range! But I have only found the same video every one else refers to "illusion at rooney", which is not at all long range.
May 15, 2018, 11:47 PM
NutBag's Avatar
Yeah they are VSWR numbers, Keep in mind this antenna is near 6 years old so Hugos techniques would have improved some.
It's fairly good right through. Ive been over 80km on 1160, adn a friend recently used it to go 117km with superb vid on 1280. Just started using 1320 now im not just stuck with Lawmates channels.
Only recently got and tried the XLR out, You can choose to just use one antenna in the software. End game is 2x Gatlings or my Gatling and Vulcan on a tracker =)
Ive been 15km out on just 2x omnis with very good vid on XLR, Im going to hold off on any comparisons just yet until I test it fairly.
I paid full price.... so if it's good or crap you'll hear about it
For Sale Electric Fuel Tank, Heavy Duty spaxton Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 31, 2013 10:25 AM
Sold Retract Shock Absorbing Strut Set (Heavy Duty) Papajeff Aircraft - Electric - Jets (FS/W) 5 Mar 29, 2013 07:07 PM
Discussion Need for heavy duty antenna tracker servo Sp1k3 GWS (Grand Wing Servo) 5 Oct 09, 2011 08:19 PM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker (((SOLD))) bah7566 FPV Equipment (FS/W) 4 May 10, 2011 01:55 PM
